what grease for poly bushings?
I use Mobil-1 Synthetic chassis grease on mine... The poly-bushing manufacturers have their own 'super-grease' that you can get from some of the sponsors. Some people use antiseize inside too.
Short answer, yes.
Any grease that is meant to be fed through the grease nipples on your hardware will probably come in either a small or large grease gun tube. Many grease guns can be bulk fed as well. (So if you buy a small grease gun because its cheaper, you can still pack it with grease from a large tube; messy)
http://www.spohn.net/category.cfm?categoryid=1059
Originally Posted by WS6FirebirdTA00
thanks man ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
