Boxed SFC's interfere with factory jack points?
Would a set of boxed SFC's such as say UMI's interfere with the factory jack points? I am wondernig because with the car so low, often I have to use the factory jack to get the car started before switching to a conventional jack when I want to lift it. I'm also wondering just incase of an emergency where I may have to replace a tire on the highway.
Anyone have any problems?
I have UMIs boxed SFCs and they hang about 1/4 to 1/2 inch lower then the pinch welds. If your car is lowered I would probably not recommend any boxed SFCs cause they all decrease ground clearance a little. I would get the tubular UMIs they aren't supposed to hang down below the body at all.
I am just concerned about getting a flat tire oneday, then not being able to use the jack that comes with the spare because my SFC's interfere.
Originally Posted by Steve0
My cars not lowered at all. I'm not worried about ground clearance. My exhaust hangs lower than the SFCs ever would.
Oh, I assumed it was lowered since you said you had trouble getting a jack under it. Mine isn't lower either and I don't have trouble getting a floor jack under it. I haven't tried the jack thats in the car. Good idea though!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
The loss of ground clearance with our boxed style SFC's and others is in somewhat a myth. You will notice other components installed on your car from factory will hang lower then the SFC's themselves. For example your stock y-pipe with hang lower then the SFC's, now imagine a set of long tubes, especially a SLP, Hooker or Pacesetter LT that reduce ground clearance greatly. Also on a Trans Am model the stock side skirts hang lower then the SFC's as well. Conclusion is you will do great damage to other components of the car before you ever get the SFC's themselves to scrape.
As for a jacking point, use the SFC's as a jacking point. It will not hurt them in anyway other the possible scratching the powder coat, so carry a rag with you.
Hope that helps!
Ryan
Hope that helps!
Ryan
Yeah I use my SFCs as lift points at work whe I put the car on a lift. Works great for that. You should be able to get a floor jack under the SFCs. I also want to say I recommend the UMI SFCs, they are less expensive then other brands and of great quality! Keep up the great work Ryan!
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
My umi boxed subframe connectors sit higher then my ORY.. they have done a great job keeping them nice and tight under the body and like others have stated i use mine as jack points in the rear the fronts i use the factory location.
Weird, my tubular SFCs (came on the car when I bought it) hang lower than anything else...
Edit: You can literally see them from the side without going underneath, I thought they were BMRs at first but I dont think they are... dont know what they are really.
No, they will not interfere with using a lift or any other kind of jack for that matter. And about the clearance thing, that is total BS. You lose clearance but it's not in a place that you need it. Besides, factory y-pipe hangs much lower than the SFC's. On my TA, the SFC's hang maybe a 1/4" lower than the side skirts and aren't even visible.
See pic for my car jacked with SFC's on. My car is also lowered on coil-overs. See any scratches on the SFC's? Get some BMR boxed, great mod and a very noticeable difference in stability and comfort. Yeah, they make the car more comfortable.
![](http://memimage.cardomain.net/member_images/9/web/453000-453999/453858_93_full.jpg)
Hope that helps!
Ryan
Hope that helps!
Ryan
Place the jack about mid door, align the jack pad on the connector and jack away ...
Geez people, he wasn't asking about clearance at all, he just wanted to know if the SFCs got in the way of the jack points from the owners manual. He never said he had problems getting the jacks under the car.
