Intrax springs
Intrax springs
http://cgi.ebay.com/ebaymotors/INTRA...QQcmdZViewItem
Anyone have these, are they as low as the sportlines?
Um... those actually look progressive to me, at least the front springs do... and according to the intrax site they design most of their springs with progressive rates.
Originally Posted by pimpmaro
Just makin a comment... I'm starting to work on compiling spring rates and characteristics to make a database, so I'm trying to keep an eye out for that stuff.
ME too Pimpmaro Check out this site hope it helps http://www.angelfire.com/my/fastcar/suspension.html
If you're going to lay out cash for new springs, might as well get coil-overs so you can actually adjust them to the exact height you need and specify the spring rate you want. You can get a set of Ground Control CO's for $450.
If all you want to do is lower the car and handling is not important, just save your money and cut a coil off the stock springs.
Yeah, I've seen that site, Uno. My plan is to get the rates, free height, installed height, wire diameter, and drop. That site gave me the idea, I'm just going to take it up a notch.
Stang Killer, I'm going to probably wind up putting it in a MySQL database and loading it up on the new website I'm building... along with a couple of other technical databases... including one on shocks. I'll be sure to let ya know when I'm gettin close... right now I'm just fighting with MySQL and it's winning.
