Emergency help needed? What could i have broke??
Last night i went out partying or whatever and we were leaving this club and i hit a Huge pothole with the right side of my car. i didnt even see it. Well now the front right side makes a very loud thumping noise. It's real bad, i couldnt go over 30 to get it to my friends house. I looked around the car last night and i didnt see anything obviously sticking out but i couldnt get underneath last night. What could this be???
nope...i dont drink and drive my SS. and it is way to loud to be a bump in the tire. any other ideas. i hit pretty hard.??
yea thats what i figured, i thought i'd ask though. And the name is Justin. thanks anyways.
Ned
Well tonight im goin to take a close look at everything to make sure it's not something simple and if i dont find anything i will definetly be taking it in 1st thing tomorrow morning. Thanks for the input.
BTW how do you like your pacesetters? How was the install?
The install on the other hand was a P.I.T.A. After I found out that the right way to do the install was to drop the K-Member and properly fit everything vice trying to cheat the hell out of it by not dropping the K-Member and possibly screwing something up; I just paid my mechanic who has his own performance shop. The labor ran me 700 bucks but that was for the Header install and welding of the HiFlo Cats and Y-pipe. A little pricey but he had it all done in about a day and I had the piece of mind that nothing was screwed up. I would have done it myself but I am lacking a lift, mig welder, time, etc.
Is it a "whoop whoop whoop" sound that increases frequency with speed? If so, you probably have a bearing yelling at you and you'll need a new hub. If it's a "thump thump" I'm still thinking...
ok guys last night i lifted it up on the jack and took the wheel off and looked at everything i could think of and found nothing. Then i turned around and looked at the wheel and noticed the nice littel dent and crack on the inside of the wheel. the noise was that bend hitting the arm that extends down right behind the wheel. so now i get to buy a new wheel. o well, at least i found out what the problem was.
Yeah your bearing might be ok. If its not you'll know it soon when it starts making a roaring noise. I would definitely not even consider reusing the tire. I don't care if its brand new, when they take a hit hard enough to crack the wheel the tire is junk. Even if it doesn't look like it. It might even drive ok for a while but you likely damaged/broke a belt inside and it could very possibly blow on you down the road, probably at high speeds which just isn't a nice mental picture. I am a professional mechanic at a chevy dealer but this is still just my 2 cents FWIW...
I absolutely agree on the tire issue. I'm a former Discount Tire technician so I'm not pullin it out of my ***. At the very least, have it inspected by a competent professional.
