turning rotors.
How difficult, with the right tools, would it be to turn my rotors.
They are starting to grind, and atm i am way, way to broke to afford the local automotive place's 136 per axel charge.
from what i know, i'd have to bleed the brake lines?
anyways, any help would be nice.
and if anyone has a link to that site where the guy has writeups on work done to these cars, that'd be nice also..
Thanks guys. I apreciate it
push the piston back in with a caliper compressor or large C clamp. clean everything up. put the rotors back on. Bolt up the bracket. lube the guide pins and install teh pads & caliper.
No need to bleed the brakes unless you take them loose (disconnect the brake lines), and no need to do taht at all.
Go to autozone and get the cheapest rotor they have, thats what I run on my car and its working just fine. I dont turn rotors, but thats just me. You might be fine with it, but ill just get new ones.
I know you are trying to do this as cheap as possible right now as cash is tight, so check around. A lot f places around here will even turn your rotors for free if you buy the pads there.
I bought a set of ceramics for the front. They stop GREAT, no noise, and very little dust. $66.
GM also says "Rotors are not to be resurfaced in an attempt to correct the following conditions: noise/squeal, cosmetic corrosion, routine pad replacement or discoloration/hard spots."
In other words, GM frowns on rotor resurfacing during what it calls "normal" pad replacement. ""
AA1Car Automotive Diagnostic & Repair Help
Ford Motor Co. Bulletin No. 99-19-04 that rotors should only be "resurfaced if diagnosis has revealed vibration in steering wheel, seat or pedal while braking. Heavily scored rotors, similar to that caused by linings worn down to the backing plate, should also be turned."
Two people can argue over anything, at any time. I didn't read that page to mean it was using the cited tech bulletin in a contentious way as much as it read that it was giving two opinions and using it to cite that side of the argument. And, that no less than GM itself was of the opinion that turning the rotors was not recommended for simple pad changes. And the FoMoCo shares that opinion. Take the bulletin alone, and there's no contention at all.
Film transfer on Ma and Pa Kettle's car? I contend that, using semi-mettalic as an example, the compound is so much softer than steel as to be irrelevant. We see that every time we wash our wheels. The compound erodes from the pad and yet the rotor remains unchanged. Could it possibly be that much of a problem if you changed pad compounds? And, if the replacement pads were of the same compound...?
And what about changing compounds. Wouldn't the new pads bed in and wear away any prior deposition in short order? Even if they didn't, what difference in performance could it possibly make?
If your premise is correct then we are all standing at a precipice of disaster every time we change pads or pad compounds without turning or replacing rotors. And yet, the two largest car companies say that is not the case...on every car they build.
Granted, specific applications designed to work together at a high performance level may be degraded to one degree or another as variables are changed, but at the performance level of a street car I would say that is not the case.
I'm not saying that you should NEVER turn the rotors, only that it isn't indicated in simple pad replacements. For those who road race or hang their *** out on public roads, they may wish to increase their performance level to what's comfortable to them. If they have enough $$$ to change rotors every pad change, good for them. But for regular folks I believe it is a lot like changing your synthetic oil every 1500 miles.
I would think about replacing the rotor or rotors with the pads.
I certainly didn't mean anything in my responses. I am simply thinking out loud in a calm, cool fashion. No offense meant.
And it's simply my thoughts that the bedding in of new brake pads will remove any transfer film and replace it with its own. I don't drive to extreme levels so I don't need to perform what I consider extreme maintenance procedures. Some pads and rotors are designed to work together or in specific combinations. Sounds like more than I need to worry about, and many others, too.
Cheers, mate!
