what causes nose dive?
The easiest way to eliminate nose dive is to run stiffer springs. If you were to slap some 600lb/in springs on the front, they would only compress half as much under the same load as the 300lb/in springs.
Nose dive is affected by spring rates, shock valving, and suspension geometry. The first two are the easiest to change, the third can get a little more involved.
Stiffer front springs and higher rebound damping in the rear shocks were already mentioned. Increasing the front shock compression damping also helps. Aftermarket torque arms help as well.
With suspension geometry, there's a parameter called anti-dive that controls the amount of suspension deflection during forward weight transfer. The load transfer is a function of wheelbase, deceleration rate and center of gravity height (another reason why lowering springs are effective). Anti-dive controls body motion/suspension movement as a result of this load transfer. If the anti-dive is set to zero, the shock and spring rates are the only things that will control this motion. As anti-dive is dialed in, the suspension arms begin to resist the load transfer along with the springs/shocks. If you were able to set anti-dive to 100%, the suspension arms would resist all of the load transfer and nothing would go through the springs. Since no load is resisted by the springs, there wouldn't be any suspension deflection due to braking even though there is still load transfer to the wheels, so there would be no brake dive. Changing this is usually reserved for race cars with a lot of suspension adjustability, though.
I also wanted to make a point that a lot of people don't realize. Stiffer rear springs will reduce nose dive as well.
As far as brakes go, they have more to do with weight transfer and then weight transfer contributes to nose dive. Instead of thinking of the brake bias or brakes in general, think more about the deceleration rate of the vehicle. The greater the deceleration rate, the more weight transfer.
Brake bias just effects the deceleration rate. Just like the pads and tires. As the deceleration rate goes up the more nose dive you get (to a limit, which is the front bumpstops). Switching to grippy R compound tires will increase nose dive, as would grippier pads.
The only thing an improperly balanced brake bias would do is limit the cars ability to decelerate which is like the opposite to having grippy pads or tires. Think what would happen if you only had the rear brakes working. You would have only 30% or so of the cars normal braking ability. That would greatly reduce the nose dive, but do you really want to do that? No.
So to answer your question, yes, brake bias can effect nose dive. Poor brakes can reduce the dive, but you want to avoid that as it is the greater of two evils. Get the brakes working as well as you can. Get the grippiest tires and pads you can and THEN worry about the brake dive.
Sometimes people think the nose dive is bad because it can happen so fast and it feels wierd. I know I don't like it. I have the Koni SA all around with 550/165lb springs, Carbotech Panther+ pads, lowered ride height and 275/315 R-compound tires. My car will still dive under braking, but it does it at a much slower rate and I have complete control. It truly doesn't bother me any more.
FastKat, if you are running the stock shocks and springs, you are probably experiencing a lot of dive right as you stomp the pedal. Just a shock change will make the car feel a whole lot more controlled because their low speed valving is what controls the body movement. Good shocks will slow the dive down so that it doesn't happen all at once. Stiffer springs will also help to slow down the body movements. You will never get rid of the dive, but slowing it way down is almost as good.
I don't know much about anti-dive geometery so I'll leave that to TooSlow02 and others. I CAN tell you that I drove a Buick LaCrosse not too long ago and as you can imagine they ride real soft and comfy. The thing I really noticed is that although they had this really soft car ride, they had almost no nose dive under braking. I couldn't believe it, no dive! It's just odd. I figure it had to be the suspension design with a lot of anti-dive built into it. I don't know much about it, but I wish our cars had some more anti-dive built it.
So they are good under braking as well as accelerating, so why not make all performance cars like that you say? Trailing throttle oversteer. It's killed many a driver before. It basically means when you get off the throttle in a corner the weight shifts to the front and the rear gets loose. The heavy engine in the back gets the car sideways in a hurry. Say you go into a corner too fast, you let off the gas to slow down and boom, there you go into the wall. If you go into a corner too fast and stay on the gas you might end up understeering and the car will plow straight. So your damned if you do and damned if you don't. The point is don't go into a corner too hot in a rear engined car.
Anyway, I like our front engined cars, they are fun and relatively easy to drive. Once you get the suspension balanced you can make the front slide or the rear slide, depending on what you want to do.
I'm starting to ramble, but I hope that gives you a better idea of how weight transfer effects the vehicle, etc...
I'm not a big fan of brake dive either, it's uncomfortable at best. You won't be totally rid of it but at least you can make a few changes to reduce it to a tolerable level. It helps to inspire more driver confidence IMO. And that's always a good thing.
