subframe connectors
There is several types you can get. Some are just bolted in, you can forget about those. Weld-in SFCs are the way to go.
Again: A very, very beneficial addition to your car!!!
I have had my f-body used from 37K. I Installed 2-point SFC's @ 57K, no noticeable difference, even though I have T-tops. @62K, I installed a set of New Dampers (specifically Koni DA's) and most of the weird noises when hitting bumps went away. @64K, I upgraded most of my suspension bushings with higher durometre rubber bushings (1LE), and even more wierd noises went away. @~78K I installed KBDD 3-point connectors, and there was no reduction in NVH, and no added performance benefits. @103K, I removed the SFC's, and guess what? Still no change. I'd also like to note that I have a total of ~40K on RR practice on the same vehicle before, during, and after the subframe connectors, and the Current milage is @117K. I have yet to see any reduction in chassis rigidity.
I do believe that the monocoque for the 4th gens might possibly twist heavily down it's middle, however I have yet to experience that on my vehicle.
Point is, depending on vehicle use and intial quality of the monocoque, I wouldn't be in a particular rush to install SFC's. FWIW, SFC's might help, but they can also be a placebo mod.
I installed UMI SFC's on my '95 Z28 when it had a bout 96,000 miles on it. I barely noticed any difference in the car's characteristics. No rattles disappeared, and the car just seemd marginally more ridgid... it was probably mostly in my head. The biggest benefit I gained from installing them was the ability to lift either half of the car by using hte SFC's as a jacking point. Upgrading the shocks to bilsteins on the other hand in combination with upgrading to a 32mm sway made a huge difference in how the car handled.
From my experience, I think the difference in chassis stiffness is more in peoples heads than reality... kind of like how people claim with their butt dynos that they can feels 5hp gains on their 350hp cars. I've even seen various posts by Strano who most people refer to as a F-body suspension expert testifying that SFC's are't necessarily all that theyre made out to be.
If youre building a high hp drag car, then yeah I could see SFC's being beneficial... but for a street car I think its definately a debatable modification
I go thru some curves and twists in the road on a daily basis and its hard to drive fast there (let alone haul ***). The car seems to throw its weight everywhere while i drive thru the curves with turns and/or twists. So my concern is neither on drag racing & autocrossing but spirited street driving without body roll limitations when on curves.
I do have a cam and bolt on setup with a built rearend so rattles do exist to me. Would those rattles go away? From what i noticed after all the modding is that adding more aftermarket parts adds more rattles haha.
The last thing i want to do is spend alot (let alone welding stuff) and not notice a difference.
Now for some more questions. What kind of dampers are you using, and are they properly matched with the respective spring rates? Also, how big are your sway bars and are they properly matched? Improvement in these areas will dramatically improve handling, and not SFC's. If you're riding on cheap or worn dampers, then any road vibrations will be transferred well into the chassis, as one of the damper's duties are supposed to dampen excessive and sometimes dangerous road shocks.
The place where 3-point SFC's will help is an application where a floor mounted torque arm is used, since the force has been transferred from the transmission mount to the floorpan.
Yes I am using poly bushing for me LCAs and I sure hate them. Only reason i got them was because my installer told me its waaaaay better and i argued its waaaay more squeaky on speed bumps. He argued it wouldnt be squeakier and unfortunately i believed him with regret now.
1) Are "Higher durometre rubber bushings" better than the stock OEM bushings? links would be nice.
2) As for the shocks and springs they are both stock WS6 stuff. If I recall correctly, someone called them "De Garbage". I have about 52K miles on the car now and I will do the following before I purchase anything: check all bushings. Controls arms, swaybar links and bushings, panhard rod. Check the tie rod ends. Also the shock mounting points as well.
3) If I understand you correctly, you are saying that most of the body roll and the 'unbalance' is more subjected to the bad/worn out shocks rather than lacking more chassis stifness (SFC). It does seem to make perfect logical sense
. BUT when i found out that Koni DA's go for $700-800 I wanted to believe that my set of shocks are fine According to other forum members, they stated the following about SFC which made me really want them! :
There is absolutely no comparison. The car is so much more rigid now. The t-tops fit tighter, the doors shut better, the interior doesn't rattle as much (that's saying alot in a big cam car like mine!) and best of all, the car turns and handles with much more stability."
So now i realized if i really want all my problems to go away not only would it cost the "cheap" SFC but shocks as well. $1,000 in parts for suspension? Sure! .... but not when im planning to sell the car in 6 months or surely less than a year. Damn it Ill have to drive like grandma now... how much are the stock shocks for? Worth it? or not?
Thanks for the reality check Foxxton. You just saved me on my car insurance by switching to stocko
EDIT: just found nonadjustable bilstein shocks on SLP for $400
. BUT when i found out that Koni DA's go for $700-800 I wanted to believe that my set of shocks are fine http://www.1le.net/ once there, click on part #'s and scroll to 1998-1999 (pretty much the same parts if you have a 2000-2002)
If you perform a search on this website, there is another, probably more comperhensive list you can go by. I'm not too sure where you can get just the bushings themselves.
2) Actually that was me. I know it will come back to bite me somehow, but It's comforting to know that my *** won't be ate up by dookie shocks, but rather what I have now (a very expensive, but well handling coil-over setup). IMHO, Koni's would be a desireable choice, but that's not my place to state what someone should do with their budget. After checking all that you stated previously, then I suppose you could consider Koni SA's, however there are cheaper options with Bilstein HD or Bilstein revalves. If you should choose new shocks, make sure you have them valved properly with whatever springs used and their respective spring rates. My advice would be to consult with some of the sponsors on this board before sinking some hard earned greenbacks.
3) Basically you're right. Shock design, spring rate, swaybar diametre, and bushing quality have a much greater effect on handling than bracing an already sturdy chassis. If I had to do it all over again, I would go through all of the above, then if I decided I really needed SFC's, I would go for something that was light, reliable, and performed it's exact function, and no more.
