How to adjust torque arm??
Old Nov 20, 2005 | 03:14 PM
Fahad's Avatar
Default How to adjust torque arm??
I have BMR torque arm adjustable and i don't know how to adjust the torque arm by angle finder?? do i need to adjusted more than once?? any difference on street and strip?? please help..
http://static.summitracing.com/globa...e/cee-5020.jpg
Thank you
Old Nov 20, 2005 | 05:29 PM
OldeSkool's Avatar
https://ls1tech.com/forums/showpost....8&postcount=16
Old Nov 20, 2005 | 05:32 PM
SLowETz's Avatar
Here ya go.... easier than typing it out-
http://www.go-fast.org/z28/pinionangle.html
Old Nov 23, 2005 | 08:52 AM
Fahad's Avatar
I really do appreciate your helps
Thank you
Old Nov 28, 2005 | 04:54 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
If you want a more detailed explanation on pinion angle & how to set it from professionals then go Here or Here
-Jay-
Old Nov 29, 2005 | 08:29 AM
JNorris's Avatar
Moderator
-Jay-
Good links.
John
Old Nov 29, 2005 | 09:10 AM
1QUIKWS6's Avatar
Since so many of us (including me) are having 'mysterious' vibration problems after adding aftermarket parts, I thought I would also post some very informative links that may explain these vibrations in a new thread of the 'Chassis, Suspension, Appearance' - 'Gears & Axles'
These links are referenced on Inland Empire Driveshaft website
You may want to take a look and make it a 'sticky'
Old Nov 29, 2005 | 01:05 PM
Fahad's Avatar
-Jay-
Very good links
Thank you
