lowering the car
Remove about 3/4 coil from each front spring and 1.25 coils from each rear spring. That should drop the car slightly less than an inch all the way around. I wouldn't remove any more than this because the stock springs aren't stiff enough to handle the lower ride height.
Now use the money you saved on the CO's to get a set of Koni shocks. The stock DeCarbons will be toast after about a year on a lowered car. Koni's are expensive, but you can save some money by just putting them on the front, with revalved Bilstiens on the rear. Sam Strano can set you up with what you need.
However, don't plan on ever hooking up or using that cam you got, unless you get lower control arm relocation brackets. Like they said above, lowering it will throw your geometry off.
Now you can get away without the adjustable panhard bar.....but those nice new wheel will look like ****. Everyone will be asking you why one wheel sticks out further than the other side. And they'll all laugh at you...
Trust me and anyone else who has done this before, do it right.
Thanks for all the help guys!!
Brandon
