awesome handling
That doesnt sound right. I think broken sway bars, flat tires, blown shocks or just a slick road and bald tires (or slicks) can send you flying.
I think you mean that you would like it to handle like its on rails.
In which case (if you want to go all out):
* shocks
* larger sway bars
* stiffer springs
* stickier tires (on larger & wider wheels to facilitate shorter sidewalls and improved contact patch)
* rod-ended rear lower contol arms
* rod-ended panhard rod
* rod-ended front A-arms
* sub-frame connectors
Thats just a rough list, not a buying guide.
This will also give you a stiff ride (since the rod-ended stuff are race parts).
You need to look at it as an entire system and buy components that complement eachother. If you want more specifics, do some searching and reading in this section (Handling & Braking) and give Give Sam Strano a call. He can help you out.
Adjustible shocks only need to be adjusted when you either, desire to change the shock performance for the desired driving condition, or change spring rate and/or ride height. The QA1's aren't really great shocks when it comes to adjustibility. Like KYB's, their single adjustible shocks simultaneously adjust rebound and compression, not particularly desirable when you really should adjust rebound when your compression is where you want it.
From what I've heard (inside and outside this forum) IAS's aren't a very good shock for high performance mobility. Before I made the move up to motorsport shocks, I ran some Koni DA's, though Koni SA's would serve you better for what you want. As expensive as they are, they're every bit worth the money.
Shock tower braces are mostly placebo when it comes to improving handling. The discussions about them has been beat to death, so I will encourage you to perform a search on that one. If you care to improve front end sway, choose a larger sway bar. The front ends on F-body's are very rigid due to a well designed K-member and front end chassis design from the factory.
In regards to trailing arms, go for a high quality rod-end, not poly. Once again this also is a beaten subject, so I will let you perform a search. Binding is what you want to avoid when it comes to handling, because it can make the rear-end break loose unexpectedly in a corner.
He is a Sponsor of LS1Tech as well.
Check out his shop online at www.stranoparts.com
