Torque Arm?
Old Jan 16, 2006 | 11:41 PM
TARZAN's Avatar
Default Torque Arm?
Well, I'm about to get an aftermarket torque arm....I'm willing to spend the $$$, just wanna make sure and get a good one...Should I get one that mounts to the tranny, or not?
Thanks,
-Will
Old Jan 16, 2006 | 11:48 PM
Foxxtron's Avatar
Are you going to modify the vehicle to drag racing better, or going towards AX, RR, or a daily driver that is improved for mostly handling?
Old Jan 17, 2006 | 12:28 AM
TARZAN's Avatar
Well, its a daily driver, that I drag race on occassion, but not too often...I'm not putting drag shocks or anything on it....Mainly plan on control arms, subframes, and a torqe arm for now....may put springs/shocks/struts on later...
Basically, I'd rather go for handling, as opposed to drag racing...though I do it on occassion
-Will
Old Jan 17, 2006 | 12:51 AM
Foxxtron's Avatar
If it's handling you're going towards, do springs/shocks/stabiliser bars first. There is a lot of hype with improving handling by using torque arms, control arms, and SFC's.
https://ls1tech.com/forums/showthrea...4&page=1&pp=10
https://ls1tech.com/forums/showt...t=398983&page=1
https://ls1tech.com/forums/showt...r+panel+dimples
https://ls1tech.com/forums/showt...rame+connectors
https://ls1tech.com/forums/suspension-brakes/398983-subframe-connectors-2pt-vs-3pt.html
https://ls1tech.com/forums/suspension-brakes/417461-sfc-s-bolt-vs-weld.html
https://ls1tech.com/forums/suspension-brakes/431250-newbie-suspension.html
https://ls1tech.com/forums/suspension-brakes/429520-sfc-worth.html
https://ls1tech.com/forums/showt...593#post4047593
I know that these are a lot of links with a lot of info, however it's been repeated, and rather than attempt to overstate placebo effects like many members do around here (not bad people, just statements with fallacies), I'd like to show you some facts. Your biggest improvment with handling will be noticeable with a proper set of shocks/springs/stabiliser bars. Eventually shall you desire a new T/A, Trailing Arms, and possibly SFC's, you could install them as well.
Old Jan 17, 2006 | 12:55 AM
Foxxtron's Avatar
but if your heart is set on getting a torque arm first, get one that mounted at the transmission, since you're more focused for improved handling.
Old Jan 17, 2006 | 01:10 AM
TARZAN's Avatar
Damn, thanks alot man, you put some time into that reply, much obliged
-Will
Old Jan 17, 2006 | 02:19 AM
Foxxtron's Avatar
No problem. It actually didn't take too long, since they were a collection of links from around the site as a result from numerous searches over my time here as a member of this forum. Now as far as the information, that took much time to examine from several other experienced motorsport drivers, here and from other forums, and from my college senior projects.
Old Jan 17, 2006 | 06:05 AM
TARZAN's Avatar
I PM'd Sam Strano last night, hopefully I can get something worked out....I read up on almost all those threads, and realized I made a mistake lol...
I purchased a Pro-Kit and some Bilsteins when I first got the car (never put any of it on though)...Looks like I'll be selling all that now though, and going with the Koni's (if I can afford them, not a clue how much they cost)....
I know its a bass-ackward suspension route, but I would like to go with the Koni's, per the request of many...And I'll go with a tranny mount torque arm, subframes, and either BMR Tubular Control arms or Edelbrock Boxed control arms (I have a pair of both laying around lol)....
That is because I do still take the car to the 1/4 track occassionally, so I'm gonna attempt to go for a kinda "best of both worlds" approach, though I realize that I can't get optimum performance for either...but hopefully it'll be better than stock, in both forms
-Will
Old Jan 17, 2006 | 11:18 AM
vigil's Avatar
Overkill for what he wants but theseare nice and don't mount to the tranny:
http://www.unbalancedengineering.com/Camaro/TA/
Old Jan 17, 2006 | 02:50 PM
TARZAN's Avatar
Thanks for the link, checking it now...
-Will
Old Jan 17, 2006 | 04:12 PM
ninobrn99's Avatar
non tranny mounted is moregeared to drag racing. if its ur DD, then go with a tranny mounted adjustable like the spohn or umi ones...
Old Jan 17, 2006 | 09:32 PM
TARZAN's Avatar
Thanks nino, thats what I'm leaning towards now....Most likely the UMI tranny mount adjustable
-Will
