do you need reloaction brackets ?
Old Feb 7, 2006 | 03:24 AM
minesfaster's Avatar
Default do you need reloaction brackets ?
Will i need relocation brachets for my bmr lower control arms, if i lower my car ? also what is the best springs to get ? where is the best place to buy ? i want to go with the pro kit the 1.2 drop.
thanks
Old Feb 7, 2006 | 08:45 AM
BMR Suspension's Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
You only need relocation brackets if wheel hop persists after you lower the car. Some cars need them some cars don't.
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Old Feb 7, 2006 | 08:58 AM
kyles2000z's Avatar
yes you'll need em. UMI makes nice ones, i think i got mine for like $70.
Old Feb 7, 2006 | 11:20 AM
Sam Strano's Avatar
LS1TECH Sponsor
I'm with Lee... some cars do, some cars don't. And, FWIW it's nice to see another vendor stepping up and tellin' it like it is....
They are far from a requirement, and why buy something you don't need you know. If you have hop issues then they are get put on the list of possible cures.
That said.... Pro-kits geneally lower more than 1.2" (and there are two different Pro-kits one could use). And if you are trying this with stock shocks you're going to be in a world of hurt to begin with. And shocks do also contribute to having or not having wheel-hop. The compression damping helps control unsprung weight (the axle) and the rebound damping the spring rate and body movement in relation to the axle.
__________________
Old Feb 7, 2006 | 08:20 PM
Why is it bad to use the stock shocks when lowering ?
Old Feb 8, 2006 | 09:08 AM
GR33N GoblinM6's Avatar
Old Feb 8, 2006 | 09:27 AM
KCFormula's Avatar
They will blow out prematurely and you will get a "bounce" in the ride.
Old Feb 8, 2006 | 10:40 AM
OneMeanZ's Avatar
Stock shocks can't dampen the stock springs correctly, no way they can dampen aftermarket springs with high spring rates.
Old Feb 8, 2006 | 12:33 PM
Runn's Avatar
What brand of relocation brackets do you recommend? BMR?
Old Feb 8, 2006 | 01:30 PM
jimmyblue's Avatar
Moderator
Used BMR bolt-ins, can't install them wrong and you can
get back what you paid.
If your LCAs are parallel to the ground you have a fairly
neutral setup. If the front is lower than the rear then you
have the geometry problem that LCA relocation is meant
to correct. If the front is higher than the rear you probably
do not need relocation. A neutral geometry car might still
see improvement in initial bite from relocation, if it's worth
the price of experimentation.
Old Feb 9, 2006 | 12:39 PM
Runn's Avatar
Thanks jimmyblue, BMR it is then.
