ADJ TQ arms
IMO, go with the non adjustable (BMR) unless you want to mess with the chassis setup which 98% of poeple dont do...it's not really necessary anyway.
Ryan
Thank you
it sounds like if i get relocation brackets, i may not need a torque arm? or is there something else i'm missing?
line angle from torque arm angle. The latter sets the
suspension reaction (w/ LCAs), the former nulls vibration.
-2 degrees is the static setting for a soft-mounts car to
get zero driveline angle under load and minimze vibe. The
torque arm angle for optimum bite is a whole 'nother
deal, wants to be set up at the nose (not back by the
pumpkin) and you can't do that without a relocating
front mount (tunnel or crossmember, either one will be
harsh). For other suspension geometry changes you may
need adjustability. But the adjustability you get within
the TA itself, is not what you need for tuning the bite
reaction. That's a misconception IMO, which just so
happens to push product.
Relo brackets are the other (easier, quieter) way to change
the instant center. Relos raise and pull back; an adjustable
TA front mount would lower and pull back for the same job.
Higher = more weight transfer, so I'd go with the relos and
only get an adjustable TA if you are dealing with a large
height difference from stock. Otherwise, no adjustment
setup hassle, no rod-end play to clunk, and less cost.
All you want really is stiffer (if you don't need to jack the
pinion angle for vibration reasons).
