UMI lca ordering question
so what is the hardware? i thought it was the bolts, so your saying i need upgrade bolt kit and hardware when ordering or just the upgrade kit no hardware? thankyou for your help
Thanks for the interest and I will be glad to help. The bolt kit is a replacement kit for the stock bolts and nuts. In some cases the bolts that are on the vehicle for a long period tend to seize and you end up breaking them, stripping them or cutting them off. This is where it is handy to have the new ones to replace them with. If you think your stock bolts will come off easy and are reusable then they are fine to reuse and will work just as well.
The grease is optional but the control arms do and will need greased. The Super Lube we sell we have found to be one of the best brands out there, that is why we sell it.
Hope that helps!
Ryan
