what are some good brakes for ls1 t/a
what are the best/good brakes for 00 T/A im intrested in slotted/crossdrilled what are some good brands out there so i may research them thanks
Friendly regards,
Originally Posted by VictorT
There are many brakes out there, but a good place to start is to ask; what are you planning on doing with the car? I have several kits that may interest you; here is a picture, so let me know if you would like additional info or pricing...
Friendly regards,
Friendly regards,
Basically my car is a daily driver. and iam eventually going to add more mods such as a cam or i may go turbo. I have a few mods now but iam intrested in getting an upgrade on brakes rather than the stock brake system i have now
Hi,
Well that is good to know... Pads are always a good place to start, but since you are considering further mods, it may be time to consider a complete upgrade. I would much rather see people considering brakes before major engine mods than after since OE brakes are not that great in the first place. Im sure it would be better to know that you have the power to stop anything your engine can put out rather than wishing you had the power after the fact. Let me know, and I will be happy to elaborate on your options... Good luck
Hi,
what would be the price of a complete set up ? cross drilled/slotted
I recently installed PBR front pads along with WS6 store front cross drilled and slotted rotors, and rear Brembo brakes with hawk pads. I love them. I used to buy Auto Zone and O'reillys rotors and pads but they always would squeal after the first three weeks. I purchased the pads and brembo blanks from sam strano performance.
Hello,
The kit shown (13inch 2pc w/ 4 piston calipers) goes for $1199, and there is a matching rear set which includes ebrake for $1619. That would be your total cost since we offer to all LS1 members free shipping and a free 6 pack of Wilwood high temp brake fluid. Now, I do have a 6 piston set up for the front as well as matching 14inch kits front and rear if you would be more interested in one of these. Let me know if you would like to know anything else.
Regards,
Originally Posted by 69TA
Victor,
Do you guys also make custom front brake rotors?
I am looking for a two piece floating rotor 14.25-14.5" x 1.25"
Thanks,
Kevin
Thanks,
Kevin
Regards
Originally Posted by mitchntx
Gm stock pads and $30 Wagners work very nice on a street car.
I ran a whole season on 2 sets Carbotech XP10s and 1 set $30 Wagner rotors on my CMC road race car.
If you want bling, S/CD are the ticket. Lot's ao WOW. But they don't add any WHOA.
Originally Posted by ls14pwr
Like he said. They look freakin awsome, but its a fact that they crack in between the crossdrilles and dont last as long as non s/cd.
The cross-drilling, seemingly the stuff of wannabe racer Civics, is worth more than poseur points; it actually helps the brakes work better. Under hard braking, a brake pad's bonding agents burn off and produce gases. Cross-drilled holes allow those gases to vent, helping to prevent brake fade. Also, when water contaminates the rotor's surface, the holes allow moisture and muck out rather than causing the pad to "float" over the surface of the rotor.
Cross-drilling also improves rotor cooling, again defeating brake fade. On cross-drilled rotors, temperatures can be reduced by as much as 200 degrees during extreme braking when compared to stock rotors. Since braking is essentially the absorption of a moving vehicle's kinetic energy and conversion into heat, rotors that quickly and efficiently dissipate heat perform better. Cross-drilled rotors increase rate of heat dissipation by increasing surface area, allowing gases to escape, and increasing air flow.
Originally Posted by 11 Bravo
I believe it depends on weather they are cheapos with the holes drilled through or if they are actually made in the molding (or whatever you call it). But they do serve a purpose besides looks otherwise race cars would not run them.
[/B]
[/B]
I will say this about "otherwise race cars would not run them"...
REAL race cars that use REAL S/CD rotors have REAL race brake budgets well into 5 figures. REAL S/CD rotors can cost upwards of $500 each and only need to last 1 race.
http://www.hrpworld.com/index.cfm?fo...action=product
Copy & Paste Moderator
Cross-Drilled/Slotted rotors are not an upgrade.
Check out this thread:
https://ls1tech.com/forums/suspension-brakes/435436-do-i-really-need-cross-drilled-slotted-rotors.html
If you really want to upgrade your brakes, get larger rotors, better fluid, more aggressive pads and stickier tires.......yes I said tires too. Tires are your car's contact with the ground. Once you lock up your brakes, its your tires that are limmiting your stopping ability.
You dont need a "big brake kit" to get larger rotors either. You can upgrade to Corvette 13" front rotors with a relocation braket. Also, pad selection makes a big difference in braking performance.
[/COPY & PASTE]
