question about lowering the car with G2 super springs
I am going to lower my Trans Am this weekend using the G2 super springs. Is there anything else that is a MUST to install because i am lowering the car? thanks
Please get a shock that is well suited for that spring. The ride will be absolutely horrible with the stock shocks. I know because i JUST swapped the G2 Super Springs out with Hotchkis Springs and threw out the old shocks and went with revalved bilstein. The difference in the ride is incredible!!
Also i don't think anyone has mentioned this. You'll want to get an alignment done after you have lowered the car.
ANY place where they know what they're doing and can perform an alignment with non-OE specs if needed. Many businesses screw this up more times than I even care to admit.
Also, on 4th Gen F-bodies it helps if they have the factory style alignment tool since that will make the adjustment much quicker and much more accurate with less frustration. You'll be amazed at how many shops don't have this tool.
