How the hell do i get the studs out?
Old Mar 29, 2006 | 12:53 PM
RedRider81's Avatar
Default How the hell do i get the studs out?
Two of the wheel studs on the driver's side front broke off. I removed the caliper, bracket, and rotor. When i searched, it sounded so easy: Just hammer out the old and hammer in the new. The problem is that both studs that broke off were broken off really deep and hammering them doesn't seem to be doing the trick. I don't know if anyone on here has had a similar experience, but i have no idea on the best way to get these out. Needless to say, i have given up for now after trying for a while to get these damn studs out. Any help or insight is greatly appreciated. Thanks.
Old Mar 29, 2006 | 12:54 PM
CrawlinWS6's Avatar
Import Patrol
When I removed mine, to install arp I had nothing but trouble. But I did get them out. Use a punch and a big hamer, and they will come out.
Old Mar 29, 2006 | 01:32 PM
RedRider81's Avatar
Thanks for the response. I feel a little better now that i took a break. I will attack with a punch and a hammer this time. Thanks again.
Old Mar 29, 2006 | 04:11 PM
Racer8102's Avatar
I used an air hammer with a pointed attachment on it, took me about 20 seconds on each stud.
Old Mar 30, 2006 | 07:29 AM
mitchntx's Avatar
Remove the hub assy as well and use something to back the hub face when you pound out the studs.
Please don't tell me you guys are pounding against the wheel bearings ...
Old Mar 30, 2006 | 01:39 PM
Steve98TransAm's Avatar
I drilled out the center of the broken studs. Then, a simple light tap with the hammer was all that was necessary.
Old Mar 30, 2006 | 01:49 PM
LiquidFire350's Avatar
and get some pb blaster on it, let it soak for a while
Old Mar 30, 2006 | 02:05 PM
MrDude_1's Avatar
please dont tell me you expect damage to the wheel bearings from a force much less then the car hitting a pothole at 30mph......
Old Mar 30, 2006 | 02:15 PM
mitchntx's Avatar
Sliding sideways?
Please don't tell me you don't understand the differences between radial and axial loading on this type of bearing.
Old Mar 30, 2006 | 03:15 PM
MrDude_1's Avatar
Sliding sideways?
try turning.
yes i realize the diff.
however the amount of force is still much less then the threshold the bearing can sustain without damage...
Old Mar 30, 2006 | 04:08 PM
67Ranger's Avatar
to get them back on, it was much easier for me to put the old stud in, then put an old open lug nut on it, and impact the lug nut on until it pulled it through. Just a thought for the re-install.
Old Mar 30, 2006 | 06:19 PM
RedRider81's Avatar
I tried to remove the hub assembly by removing the four bolts and it does not seem to want to come off. I don't think i am missing anything, am i? I'm going to attempt to drill them out tomorrow. I tried to use a punch tonight and i had no luck.
Thanks for the tip. I hope re-installation will be much easier for me.
Old Mar 30, 2006 | 11:30 PM
69TA's Avatar
Yeah I was just about to say that. Taking off the hub assembly is a real bitch. And my car only had 25K miles. Definately soak it in some rust penetrante before attempting removal. Then it's still a bitch.
Once they are off. Lightly sand the inside spindle hole and reassemble with anti sieze.
Old Mar 31, 2006 | 06:27 AM
mitchntx's Avatar
try turning.
ANY side loading of roller bearing is a bad thing.
These hub assemblies are pressed together and use a crimp to hold them in place. Side loading presses against the crimp. It's a grossly poor design.
In Texas, the assemblies just come right out ...
Old Mar 31, 2006 | 08:32 AM
marv's Avatar
Also might want to consider heating the area (on the hub assembly) around the stud with a propane torch. This will expand the hub assembly ever so slightly and might enable you to drive them out. Might take a few minutes, but I've done it before and it works alright...
Old Mar 31, 2006 | 10:37 AM
CrawlinWS6's Avatar
Import Patrol
Not all the time. When I put my 7.5 arp wheel studs in, The impact did not work well, (over 1,500 lbs of torque). I finally took the spindles off and had them pressed in.
