Koni's with Stock Springs
Can someone post some pics of cars using hose mod and lower perch with this set up. I'm thinking of going this way but want to see how it looks first.
Thanks
Thanks
Well I dont have pictures right now, but I just put koni sa's and stock springs on the lower spring perch. I dont have pictures right now but i'll post some asap.
I dont have the rear konis in yet, but i will do the heater hose mod
Koni Sa's rear spring perch removed
front on lwr spring location
I love the way it sits and handles
some say go lower but i dont want the low clearance issues
flozram,
vbmenu_register("postmenu_4528113", true);
Did you have to change your pan hard bar or anything else? How does the rear end sit as far as side to side? Is it in the center still?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Looks great, thanks.
Sold The Fun Stuff :(
I have the same setup (Koni SAs on the lower perch in front, rear isolator removed). I am still thinking about modifying my rear springs by cutting off a half coil or so to drop the rear another 1/4" but after that the car should sit PERFECT if you ask me.
My car rides MUCH better than stock, handles MUCH better than stock, and looks like it should have when it was built. Not too low, not too high. I do have true duals as well and I have plenty of clearance (something I didn't have at all when I had a Pro Kit on the car with the duals).
![](http://img409.imageshack.us/img409/3909/img11691vs.jpg)
![](http://img409.imageshack.us/img409/9639/img11511pu.jpg)
Beautiful stance, it doesn't need to be any lower, it looks good just the way it is. What size wheels are those?
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
Sorry fell asleep there
yes adjustable panhard bar ceneterd everything
again i am conservative so the rear wheels are 10" not 11"
so there really is no clearance issues
the front Koni's have a C-type clip that gives you an inch or so of ride height difference thats all it takes to lwr the front
thanks
thanks
Damn ... when I had my car sittin on the lower perch up front and the rear spacer removed my car didn't sit anything like these cars. My front end was jacked up compared to the rear ... I wasn't happy with it all. If my car had looked like those though, I would have kept the setup.
No adjustment necessary, just move the clip down and put the spring perch back on. Simple and easy. I had a buddy of mine (the guy with the black Trans Am) who had the Koni SAs with stock springs on his car and he said his didn't sit like mine sat either. If you notice some cars sit different from the factory (mine was way up in the front and the back) so that may have something to do with it. With the Konis though the car sat down nicely.
Originally Posted by Bowtie Guy
Here ya go. 02 Z28 with Koni SA lower perch and rear hose mod.
