Royally f'd up the brakes today
So I went to put the breaks on the better half's Ta today. We picked up the Hawk front and rear pads and the slotted and drilled rotors from the ws6store
http://www.ws6project.com/user_stor/...27027ae66090f7
So I button everything up and start the car. As I put the car in reverse, it goes nowhere. So I give it some gas and it moves out. Take it down the road and start the break in procedure. As I come up on a stop sign and hit the brakes, BOOOOOOM. Something breaks free and I have to really jump on the stop pedal.
So I pull the car back in and the passenger side front rotor and completely broken in half. The center section of the rotor broke away from the rest of it. Any ideas on what I f'd up and why? I am definitely
now. I'm now relaxing for the rest of the day and I'm going to have a few dozen
![Gay!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_rainbow.gif)
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
My hunch is that you had a stuck slider pin and the pads had the rotor on a bind (which is why it didn't want to go anywhere in the first place). Then when you applied the brakes, it pulled the rotor "sideways" since the caliper was stuck and not floating as it should be. Once it bound the rotor enough, it broke. Cast iron is brittle, so it won't put up with that kind of force.
Just my guess.
(And if so, I doubt they will warranty it since it's not a problem caused by a defective rotor).
Just my guess.
Thanks for the responses guys. I'll be calling the ws6store later today to see if they will just sell me the passenger side front rotor.
Is there a way to check the slider pins once I install the rotor again?
Damn, that's pretty much what happened. It was a little difficult to get the caliper on and lined up. Now I know for next time. Thanks!!
LS1TECH Sponsor
Sounds like something was messed up.
BUT, slotting and/or drilling rotors weakens them. I've never seen a rotor break in half, even with stuck sliders that completely tore up a set of pads.
Then put the added weakness together with a cheap set of rotors, and I'm not suprised.
__________________
