lightest subframe connectors
http://www.umiperformance.com/2001.aspx
http://www.umiperformance.com/2002.aspx
Hope that helps,
Ryan
Hope that helps,
Ryan
I would check the Spohn website again just to be more accurate, but that's the best that I can remember them. (I bought the chrome-moly SFC's).
I have Wolfe's chromoly SFCs and they are very light and made with great quality.
I have heavy, boxed, x-braced SLP subframes that shoud be around 40+ pounds. Those pieces of pig iron are bullet proof and that's what you want in a subframe.
I'll take 30 years of service in trade for an extra 10-15 pounds compared to a less rigid design just for the sake of saying you have sub-frames.
Chromoly is stronger than the mild steel and it's lighter so while you may think that having a 40 pound boxed SFC means it's going to be stronger that isn't going to be always true. I'll put my Lighter SFCs by wolfe up against any others out there. If you want something that's really going to be strong then you need the through-floor SFCs that Wolfe makes.
When it comes to straight bolt on/weld in sub-frames I think SLP has the best part out there IMO.
That's the only aftrermarket part I'd buy from SLP though. ~Joshua
It's really handy to be able to jack up one side of the car at a time like with the boxed ones but i'm also looking for a very light subframe connector.
And has anyone thought about the tubular chromemoly ones that Hardcore makes and uses on their 7 second TA?
http://www.wolferacecraft.com/detail.aspx?ID=251
Hope that helps,
Ryan
Wolfe's are weld in
BOSS APPROVED!
