What tq arm will work w/ 9" and td
Well I think it's time to upgrade the torque arm, and I'm just wondering what will fit with my setup so I don't have to worry about it not working during the install
I have a moser 9" rearend with 3" true duals that end before the axle. Any proven fits would be very helpful. Thanks
Our transmission mounted torque arm will clear with a true dual system and fit on a 9". The pictures below show this item installed with a true dual system, it actually adds some addtional clearance over the stock arm. If you have any questions please ask and I will be glad to help.
http://www.umiperformance.com/2205.aspx
Installed Pictures-
http://www.umiperformance.com/images/2205l.jpg
http://www.umiperformance.com/images/2205m.jpg
Hope that helps![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Ryan
Installed Pictures-
Hope that helps
Ryan
Most of the after market torque arms will do the job. HOWEVER, many of the after market arms have a problem with the Moser 12 bolt design. The bolts holding the torque arm at the rear tend to back out. Since you are going with a 9", you should be OK.
Originally Posted by Bearcat Steve
Most of the after market torque arms will do the job. HOWEVER, many of the after market arms have a problem with the Moser 12 bolt design. The bolts holding the torque arm at the rear tend to back out....
Just use drilled bolt heads and safety wire. Zero Problem in the four years I've had my 12 bolt.
Steve
Originally Posted by blue01ta
Ryan, do you have a body mounted adjustable T/A for the same setup? Wouldn't that be better for him?
Hope that helps!
Ryan
