Umi LCA's, which ones?
Im thinking about getting LCA's from UMI but am not sure which way to go. Im leaning towards the poly/rod. This is a daily driver which will see some track use. I was hoping to get a little better traction and handling. What are your opinions for a car thats gonna get mostly street use?
Originally Posted by Ericbigmac83
Cool, Anyone else have opinions on lower control arms for a mostly street driven car?
Originally Posted by coolformula
I thought POLY can bind. I would go rod/rod
Yes polyurethane does and can bind when pushed to its limits. That is why we offer a compromise between the two. The rod/rod set us is excellent and works well, however many do not like this set-up since there vehicle is more street driven then anything. The poly/rod combo is the best bet for the street, the rod end helps to eliminate the rear end bind while the polyurethane bushings bolt to the chassis to help absorb any road nosies before they enter the passenger area. We usually always recommend this set-up on a street car exposed to some handling. They also offer adjustability if ever needed.
If I can help anymore please ask. Thank you!
Ryan
www.umiperformance.com/2016.aspx
LS1TECH Sponsor
Poly/rod is what I recommend and sell in most cases (UMI's no less). They cost more than all poly, but don't monkey with the roll stiffness and progression like all poly arms do.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
The overall bind that would be present in a Poly/rod combo would be ~10% more than a rod/rod combo of the same or similar design.
From my experience, the only quality I don't like about poly in a bushing of that type would be it's creep (cold-flow) properties. It can take quite a while before it's obvious, but the reason I prefer a solid rubber is due to it's higher ratio of elsatic monomers, rather than the plasitcity of the mostly amorphous polyurethane.
LS1TECH Sponsor
I can't quantify it. But it would be worse with in a boxed or tubular arm than with poly bushings in a stock arm (which itself will flex). But the difference is pretty large based on my experience. Again, I can't put a number on it but it's noticeable and significant.
__________________
I like how my thread just opened all back up 3 months later, I think i am going with the UMI poly/rod LCA's....just as soon as my bank account starts going back in the positive direction, lol
Originally Posted by UMI Performance
Hello,
Ryan
Ryan
Originally Posted by shudog
I got the same set and they are way noisier than stock. So bad i want to put the stockers back on. And before anyone even says it, they ARE tight. But they look nice and fit up perfectly with the UMI SFC's and PHB.
Hope that helps!
Ryan
A few things to try. First and most important is make sure the rod end in sitting straight, or in other words not twisted to one side.. this can cause noise. Also make sure the jam nut is very tight. The last thing to try is adding a thick layer of Teflon tape to the rod end threads and screw them back into the control arm, this will tighten the threads and possibly cure the problem.
Hope that helps!
Ryan
Hope that helps!
Ryan
I think a lot of the problem is from my PHR (body side) because the bolt had a messed up thread and I think it messed with my torque reading.
