do i need relo brackets for the LCA's?
Old Jul 5, 2006 | 10:46 PM
erikthegoalie's Avatar
Default do i need relo brackets for the LCA's?
DO i need relo brackets for my BMR LCA's....
car is lowere 1.25 in rear....
i dont notice any bad wheel hop...but ive heard on lowered cars the relo brackets are good
lemme know
Old Jul 5, 2006 | 11:38 PM
94z28L's Avatar
nothin is really required but they are a very good idea as well as a good alignment
Old Jul 5, 2006 | 11:46 PM
99HOSS's Avatar
you need to look at the angle of the LCA's an see if they go up from chassis to differential. If they do, you'll need to add re-lo brackets to (at least) level them out
Old Jul 6, 2006 | 09:29 AM
will take a look THANKS!
Old Jul 6, 2006 | 11:35 AM
black01_WS6's Avatar
hey erik you really don't want your lower control arms to be level, you actually want them pointing down somewhat. I have the relo brackets on my ride and noticed the difference.
you may not have wheel hop now but as soon as you add some more power to the ground you will get some. They are pretty cheap to buy, I would just get a set and next time you are working on your car throw them on.
Old Jul 6, 2006 | 02:33 PM
i think i will...bolt on or weld in??
what is better
erik
Old Jul 6, 2006 | 02:55 PM
ICRAZY6's Avatar
Weld in. They are alot stronger.
Old Jul 6, 2006 | 02:57 PM
bigdsz's Avatar
They are bolted on, but must be welded. Check out UMI, great quality.
Old Jul 6, 2006 | 03:59 PM
I went with the Spohn relo brackets made for a 12 bolt. fit great. I am gonna check them this weekend and I might weld them.
I would wait to weld them on to make sure there are where you want them, mine have 2 settings I can use.
