Getting subframes...torn between KBDD and Global West
As for LT headers, yes, you'll have to take that into consideration, I'm getting FLP's and I talked to Mitch about it and he is Custom fabracating a y-pipe to fit for me, it's a little extra $$$ but I'd rather Not cut out my Sub Frames and replace them with tubular or boxed, the DD design is allot stronger and my car is much more ridged than my friends with Tubular...
Email me at dvdoug@hotmail.com if you want it.
With the Global's....any clearance loss or access probs? I prob leaning more toward the KB's if there is not a big access problem and if my ground clearance will be fine after lowering the car 1.5" in the future. Thanks for the help guys. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
This is off topic, but wanted to know if you still drive around with your ss license plate cover in the back ? Any problems with the local cops ?
Unfortunately, I don't have any pics of the GW SFC's on the car, but will try to explain as best I can. They install inboard of the factory jack points by about an inch. At the front they "cup" the back end of the front subframe, they then bend outboard slightly and run parallel and inboard of the pinch weld. Looking from the side they are totally hidden behind the pinch weld except for the very front where they have to drop down a tad to attach to the subframe. At the rear they fit up into the door sill cavity next to the rear subframe and are welded to the side of the subframe and around the cross-section of the door sill cavity. Kinda hard to explain without pics, but I haven't had the car on a lift to get any good ones.
Yes, I routinely jack the car by the subframes at front or back. It's difficult to jack them along the length of the SFC just because they are tucked up so tight. If you can get your jack pad on them you can jack it anywhere along the SFC though. They are VERY solid.
Hope that helps.
They weld at those points for a VERY sturdy connection. You can use them as jacking points anywhere on the bars.
No problems with install. No need to pull up carpet, move lcas, fuel lines or anything to weld them.
Go Global! No regrets. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
