SLP Line Lock
Good, bad ?
How is installation?
works the way it suposed to ?
Thanks <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Chris
You step on the brake, hit the linelock button and it locks the line pressure to the front brakes.
This valve can malfuncution at some point. With SLP, you'd have to buy a new unit, Hurst, you could rebuild for $30 or so.
I have the ThunderRacing kit and couldn't be happier with it. The lines were pre-bent and fit perfectly.
IS hole behind pcm , but i drill hole beside steering colum also ( drill from inside out ) put a peace of rubber hose in hole ran wire inside hose, then use same type wire wrap as GM,tie wrap to the big rubber hose comming over master cyl
I also mounted switch in ash tray
just finished 4:30 pm today
my .02
PS ::Connect brake line to master cyl and line lock ,the second line which goes to ABS block start it but leave it loose,remove cap from master cyl and let the lines grivity bleed watch the loose connection untill all air is out and run pure fluid ( may shake the line a little to help bleed ( REMBER BRAKE FLUID WILL RENOVE PAINT
I placed plastic sheet over fender)if does not gravity bleed blow into master cyl and have some one watch for fluid at ABS block >>>THIS way you do not have to bleed the brakes from under car- I had no problem of any kind
also the picture from SLP is UPSIDE DOWN install with the wire connection UP
Sorry for the long post, hope it helps
