problem with bmr adj. torque arm!!
What model TA do you have? What Sub frame connecters do you have?
Tom
anybody else have this problem? they say to use the factory bolts <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Check for slop in the mounting plate. It should fit snug.
Good luck
Tom
btw do you have any good tips on setting the angle?
As for the pinion angle they sent me an Angle Finder and the directions they sent (or you can get them on there website) showed me how to get it.
Bruce
<strong>
As for the pinion angle they sent me an Angle Finder and the directions they sent (or you can get them on there website) showed me how to get it. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">yeah they sent this as well, but it is kind of vague as how exactly to set it. the finder doesn't show +or- just the numbers. what i don't understand is lets say for exampl you have a -6* D/S angle on the left of the dial and a -3* on the rear end. do you subtract these and get -3*? or what? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 98BlkBrd:
<strong>
As for the pinion angle they sent me an Angle Finder and the directions they sent (or you can get them on there website) showed me how to get it. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">yeah they sent this as well, but it is kind of vague as how exactly to set it. the finder doesn't show +or- just the numbers. what i don't understand is lets say for exampl you have a -6* D/S angle on the left of the dial and a -3* on the rear end. do you subtract these and get -3*? or what? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If you have -6 on the driveshaft and -3 on the axle, your pinion angle is -9.
Bruce
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by YT FIRE:
<strong>
Bruce </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That is not the way I understand it.
The guage supplied by BMR does not have the minus or plus on it for a reason. The minus side will depend on which side of the car you take your measurements from.
OK, Lets say the drivers side is where you take the measurements. The angle finder is on the drive shaft and the drive shaft is "naturally" angled down to the rear. The angle finder reads 6 on the left side of zero on the angle finder which would be a minus -6.
If you measured from the passinger side the 6 would be on the right side of zero on the angle finder. This would also be a minus -6 . Get it?? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Now, you put the angle finder on the rear end torgue arm mount and lets say that reads ( from the drivers side) 2 on the right side of zero. This will be a plus + 2. This adds up to a total of 8. Then divide by 2 and your pinion angle is minus -4. This is the way I understand it. Please correct me if I am wrong.
BTW, BMR was very helpful with my questions. They also sent me the longer bolts overnight like they said they would. I would do business with those guys anytime. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Good luck
Tom
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Hardtop:
<strong>
Good luck
Tom </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Tom that is correct. I'm assuming that he knew if the angle gauge was showing the driveshaft or the rear were pointing down or up. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Your math is correct -6 on the drive shaft and + 2 on the axle = -4 total pinion angle. My math is correct too. If your -2 on the driveshaft and -2 on the rear, your pinion angle is -4. Wish I had the same luck as you getting longer bolts from BMR. I think their stuff is great and would buy from them again too. Guess I'll have to call them again and see if I can get them to send me some bolts. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Bruce
Bruce </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">i understand how Tom is getting his, but i don't understand how you say both of yours is correct. it looks like you are just adding the two together. wouldn't yours be 0 <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Bruce </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">i understand how Tom is getting his, but i don't understand how you say both of yours is correct. it looks like you are just adding the two together. wouldn't yours be 0 <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If your driveshaft was -2 and your rear was + 2 you would then be at zero. My car is - 1.5 on the driveshaft and -1 on the rear for a total of -2.5.
Bruce
The degree measuring device is like "clock time" where the difference between 2 minutes before the hour and 4 minutes before the hour is 2 minutes. The difference is what matters to the working angle, rather than whether the car is parked pointing up or down your driveway.
HOWEVER, the pinion is supposed to be pointed down more than the driveshaft by at least 1 or 2 degrees, so when the pinion rotates up on acceleration the working angle stays below a zero angle. Ultimately it must depend on how stiff the springs, shocks and bushings are, and how much torque is developed at a standing start, to guess at how many maximum degrees of upwards pinion rotation is possible.
To look at the other extreme limit, if the working angle is over 6 degrees the driveshaft is noisy.
I have a lightly modified 1LE with 275mm street tires and use 1 1/2 degrees for the static working angle and it seems fine. If you have stickier tires, a softer rear suspension, numerically higher rear gearing, or more torque I think you need more working angle to keep the pinion on the same amoount of ultimate working angle. Maybe 3-4 degrees, tops.
