subframe connectors - would they help in a bad car accident?
subframe connectors, would they help in a bad car accident
would subframe connectors help in a bad car crash i know this is kind of a wiered question but wouldnt they help keep teh cabin rigid?
Tech Resident
do you mean will it let the chassis twist less? probably, but it's like a band-aid on a bullet wound. it's kinda like is it fucked in the *** or just fucked? either way, it's still fucked. not the most eloquent way of saying it, but...
sub frames are to keep your chassis rigid during hard launches, they will not do anything for your car if you get into an accident. thats like usinga bullet proof vest against a missle....ya it may do something but your still fucked!!!!!
I'd imagine they'd probably be worse than not having them in at all. It's gonna put more force on the car that hit you, and if the chassis doesn't flex, that's more energy being funneled into your meat-bag of a body
Tech Resident
Copy & Paste Moderator
Keeping the chasis rigid in the area of the passenger compartment is a good thing. Modern cars are designed so that the front and rear will crumple while the passenger compartment stays intact and often the doors are still openable. Now whether SFCs will enhance or inhibit this, I do not know. Its possible that they may make the passenger compartment more rigid and help in the event of a severe accident. Conversely, they may cause forces that would normally travel under the car to enter the passenger compartment. I dont know which would happen and I dont know if any studies have been done.
VIP1 is on the right track. I think the logic might be flawed. A stiffer chassis with subframe connectors would create a stronger structure, true. But this stronger shell would mean that energy that would otherwise be absorbed from the body contorting would be spent creating movement of the vehicle. I am thinking of this kinda like a spray can when you shake it. The little ball inside is bouncing all around the stiff containing structure. I think it is more likely to cause occupant damage. After all race car drivers use 5 point harnesses, specific seats, HANS devices and helmets for a reason.
Here is the corresponding thread in the Handling & Braking section:
https://ls1tech.com/forums/suspension-brakes/550428-subframe-connectors-would-they-help-bad-car-accident.html
Originally Posted by VIP1
Thats not neccssarily true.
Originally Posted by hallass
bingo. i know where there's a gorgeous ws6 sitting that had a front end collision that actually wouldn't have been all that bad, but it had weld in subframes and the car's unrepairable do to them transfering the force through the rest of the car instead of the "crumple zones" taking the blow. seeing this definitely changed my mind about sfc's. if it was a pure race car i'd do it, but my car spends 98% of it's time on the road where there's always that chance...
