Lower control arms
Old Aug 16, 2006 | 01:52 AM
LSGunZ28's Avatar
Default Lower control arms
Okay... Im finally ordering parts for my car
I just ordered LTs and ORY a week ago, a Findanza LS2 aluminum flywheel today and tomorrow ( as soon as someone responds) get my LS7 clutch kit and my lower control arms.
What kind of lower control arms should I get.
I dont want to put in anything over 200.
Is Spohn a good brand?
I normally take my car to the strip. So I want something that I can feel a big difference with.
Basically what lower control arms are good and not too pricey.
and will this eliminate a lot of wheel hop? and save my stock diff and driveshaft longer?
Old Aug 16, 2006 | 01:58 AM
00cls1camaross's Avatar
i just installed mine with the brackets
the only thing i could tell was a lot smoother burnout... the arms and brackets only really help when you launching at high RPMs and can dead hook
i am an unstalled A4 so i wouldnt know how they felt on hard launches yet... they guy that did put them on said they would help .1 with my 60 ft on hard launches
i got bmr tubular with bolt on brackets
Old Aug 16, 2006 | 02:26 AM
LSGunZ28's Avatar
I was looking at the Spohn adjustable lower control arems that are tubular and help eliminate wheel hop or some junk like that on Byunspeed.com they were $200 if I am not mistaken
Old Aug 16, 2006 | 08:15 AM
BMR Suspension's Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I would recommend using a pair of standard non adjustable lower poly/poly control arms (part# TCA001) or if NVH is an issue with you we do offer a poly/rubber control arm (part# TCA002) that has shown no decrease in performance over the poly/poly combo. Just let me know if you have any other questions or concerns with our products
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Old Aug 16, 2006 | 05:47 PM
LSGunZ28's Avatar
I know you are gonna give a biased answer, but here it goes anyways.
what is a better brand? Spohn or BMR
Old Aug 16, 2006 | 06:21 PM
SJM Manufacturing Inc's Avatar
...I normally take my car to the strip. So I want something that I can feel a big difference with.
...Basically what lower control arms are good and not too pricey.
As Lee mentioned, his control arms are a good value and something you may want to consider... and will come in under 200.00.
Something that you would feel a big difference would be double adjustable rod-ended components. We've got a special that we have running and meets your budget at under 200.00. www.sjmmanufacturing.com/deals.html
Old Aug 16, 2006 | 08:07 PM
LSGunZ28's Avatar
cool. I wish other sponsors responded as fast as you guys do.
Old Aug 17, 2006 | 01:49 AM
LSGunZ28's Avatar
Im on the ordering page of the adjustable Spohn LCA with polyeurythane bushings, and upgraded to the chromemoly and red color ones.
on Byunspeed.com
Im gonna wait til morning and if no one can tell me of a better deal, Im buying those ( 215 bucks or so)
Old Aug 17, 2006 | 01:34 PM
Shadow1999's Avatar
I'm in the same dilema as you but after LOTS of reading, will most likely be getting the SJM rod/rod LCA/PHB kit which comes w/upgraded bolts for just over $300. I'm just going to coat it myself; not worried about powder coating. Now to decide which to get first, LCA/PHB or LT's and Y. Already got the motor and tranny mounts waiting for install (needed) so I might to the latter first.
Old Aug 17, 2006 | 02:46 PM
LSGunZ28's Avatar
Im only gonna get the spohn from Byunspeed if texas speed cant give me a deal on their LS7 clutch kit, because Then Im gonna order everything from Byunspeed and save on the shipping. If I get a deal from Texas speed I will buy my control arms from SJM
