CTS-V brakes, something different
Old 07-31-2008, 12:38 AM
  #321
ae13291's Avatar
would 3rd gen spindles work on the 4th gen? and 13.4 rotor fit under 17's?
Old 07-31-2008, 01:01 AM
  #322
some_punk's Avatar
Originally Posted by JasonWW
I'm not sure what car you have, but if it's a LS1 F-body and you have the stock brakes, just measure how much spoke clearance you have. This setup sticks out about an 1 inch more.
Yes I have a 2002 trans am. And as for the brake hoses, I would like to get steel braided brake hoses, do I get the hoses for a f-body or cts-v?
and as for caliper clearance i guess I should measure for about 1.25 inches just to be safe? And would the rear cts-v calipers be a direct bolt on too?
Old 07-31-2008, 01:07 AM
  #323
JasonWW's Avatar
3rd gen uses struts, 4th gen is SLA. Not even close to the same.
There is a picture of a 13.4 rotor in a 17" rim right above if you look.
Edit: you already saw that pic in the other thread. why are you asking this?
Old 07-31-2008, 01:13 AM
  #324
JasonWW's Avatar
You can always add a 1/8 to 3/16 spacer if you need a little extra.
I'm guessing you want to do the rears for appearance sake?
I have no clue about their fitment.
Old 07-31-2008, 02:07 AM
  #325
ae13291's Avatar
i wanna double check everything, im currently going to hunt for some 13.4 rotors from a Z51 c6 and some evo brembo calipers and im going to make my own brackets, if this is all successful then we can maybe start selling the brackets to put all this together.
Old 07-31-2008, 02:12 AM
  #326
JasonWW's Avatar
Keep in mind some rims are barrel shaped. They will get smaller near the spoke side. YMMV.
See if you can get a rotor from Autozone so you can mount it and then return it.
Those EVO calipers can't be cheap. What do they run?
Old 07-31-2008, 02:15 AM
  #327
ae13291's Avatar
^^^ correct, i kinda noticed that with the 10 spokes, it looks as if the center of the rim is pulled more inn
Old 08-02-2008, 01:39 AM
  #328
some_punk's Avatar
so would stock f-body brake hoses and banjo bolts work with these calipers?
Old 08-02-2008, 09:06 PM
  #329
rat496boy's Avatar
so the caliper sits a inch closer to the wheel then a factory set up does? does it push the wheel out any? i have a 18inch 3 peice Iforged and i think i can get these to work in theroy depending if it moves the wheel anywhere.
Old 08-02-2008, 09:29 PM
  #330
Manic Mechanic's Avatar
This stuff does not move the wheel out any. The only thing between the wheel and spindle hub is the brake rotor hub section. The vette rotor and the F-body rotor are realatively the same thickness there. You had better have an unusually large gap between your wheel and stock caliper if you want any chance at all of bolting this on. If you have a wheel that clears the CTS-V caliper, it is a bolt on with the vette rotor.
Vernon
Old 08-02-2008, 10:53 PM
  #331
ebmiller88's Avatar
You would need longer custom lines for this install as the banjo fitting is a bit lower than the stock LS1 setup is, I can provide these. Again, fitment will depend on which wheels are used. The rears will not be a direct bolt on, totally custom setup. I have not yet looked into it as the front issues aren't ironed out.
Ed
Old 08-02-2008, 10:54 PM
  #332
ebmiller88's Avatar
Banjos, yes, but not the lines.
Ed
Old 08-02-2008, 10:55 PM
  #333
ebmiller88's Avatar
This rotor doesn't move the wheel out any, it's the caliper clearance that is needed. If you need any help let me know.
Ed
Old 08-02-2008, 11:50 PM
  #334
some_punk's Avatar
Ed
If I can use the banjo bolts, then which line do I use? Would CTS-v brake hoses work?
Old 08-03-2008, 12:18 AM
  #335
Pipelayaz's Avatar
That'd be really cool if you guys could get this to fit. The C6 z06 kit is too heavy..
Old 08-03-2008, 01:13 AM
  #336
ebmiller88's Avatar
How 'bout a 14" kit with a C5/C6 base/Z51 PBR caliper?
OR, a 14" kit using a Wilwood 6 piston SL6 caliper?
We can do a lot of things here if you aren't stuck on the caliper.
Old 08-03-2008, 01:14 AM
  #337
ebmiller88's Avatar
I am unsure as to what size/type the brake line fitting is on the CTS where it connects to the chassis. We'll get to that once we get the brakes to fit, lines are easy.
Ed
Old 08-03-2008, 02:40 AM
  #338
some_punk's Avatar
Ed
Hope you can find it soon so I can do it too I like the cts-v caliper's look better than c6 z06 and i think there would be more pad choices too.
Old 08-06-2008, 09:43 PM
  #339
some_punk's Avatar
Btw, i am looking for after market rotors for this setup, is DBA rotors any good?
http://motors.shop.ebay.com/_Car-Tru...fxdZ1QQ_ptasZ1
I heard about the oem rotors not being directional so I would like to know what other choices I have for rotors? And has anyone figured out which brake hose to use?
Old 08-07-2008, 01:18 AM
  #340
JasonWW's Avatar
That's not what I said.
The caliper adds about 3/4" and the Vette rotor offset adds about 1/4". That's why I said you need about 1" of spoke clearance if you have stock F-body rotors right now.
Kore3 has offered those brackets for a year or 2 already.
Not only are there a lot more choices, they are much cheaper - as well as much thicker which means they will last longer.
Quick Reply: CTS-V brakes, something different
