Bought a Hotchkis lowering kit. Do I need an Adj. Panhard Bar?
I was wondering if I need an aftermarket adjustable panhard bar now that I will be lowering my car. I noticed that a lot of you guys/gals are running one. Is it necessary or is a preference thing in order to get more effieciency out of the kit? Any help would be greatly appreciated!!
Kenny
Kenny
I considered it a "need". Your rearend will be off-center when you lower it, though by how much tends to vary (GM's tolerances aren't spectacular when it comes to this). Find a shop that can do four wheel alignments and have them do the front end and center the rearend at the same time.
-Mike
-Mike
Partially on-topic, but I also have Hotchkis on all four's and my my passenger-side rear sits about 2 inches higher than the driver's side. My adjustable PHR is sitting in the closet, waiting to be put on. This would fix the issue, ya?
It might help a little, but more than likely you need to rotate your rear springs. I start with the tails pointing forward and adjust from there. My driver's side is about 1/2" higher than the passenger side, until my fat *** hits the seat.
-Mike
-Mike
My rear was centered fine with Hotchkis springs and a non adjustable BMR bar. Comes down to build tolerances I guess. I'd say put the springs in first and see if you need an adjustable bar to get it centered up.
