Q's about Caliper paints?
i plan on sanding the calipers down before painting. i bought a can of duplicolor caliper paint in black but also want to try and clear them but didnt see any duplicolor clear so i got engine enamel paint in clear. does clear just leave a better look? will this work and also should i put the decals on then clear them or wait until everything is done to put the decals on. one more....did anyone use any primer, how will primer help and what is it. sorry for all the questions but i just want to do it right! thanks for the help
Originally Posted by YouCantCmyZ28
I bought a can of duplicolor caliper paint in black but also want to try and clear them but didnt see any duplicolor clear so I got engine enamel paint in clear. Does clear just leave a better look?
Should i put the decals on then clear them or wait until everything is done to put the decals on?
One more....did anyone use any primer, how will primer help and what is it?
You may want to try the appearance and detailing section for more info.
Chris
I did just what you are planning to do about 2 months ago.
I recommend you pull the calipers off and paint them.
I did a drill with wire wheels, course then fine. Then a sander with 80 grit, 120 grit and hand sanded with some 220 and 400. They looked very smooth but the first 2 layers of primer I put on showed some very very very small imperfections in the finish job I did but with layers of primer and paint they went away completely.
I did use the same paints you are using and same clear.
4 layers primer (light coats)
3 layers color (first light, 2nd heavy and 3rd light)
5 coats of clear (really built up a clear coat)
Did the same for the caliper brackets too.
Calipers in red, brackets in black. Calipers jump out at you and you have to stare to see the brackets, just what I wanted.
Oh and I put the Trans Am decals up front and just about everyone I work with has commented on them. If you get the decals put them on before the clear coats it really will help them stay clean and makes cleaning a snap.
I had some high temp clear engine enamal, and used it on my buddies calipers (my car is in the shop) and it was cloudy. as it dried it got worse so we stripped it down to start over. anyone else having this problem or did I just get a bad can? (and yes I'm sure it's clear!)
