Shock perch (front)
Old Oct 15, 2006 | 04:08 PM
orbee's Avatar
Default Shock perch (front)
when swapping out shocks on the front , do i use the original perch for my new shocks ? does the perch come off the shock easily ? thanks again...
i looked at the sticky about lowering for newbs , but it did not mention the perch removal ...
Old Oct 15, 2006 | 08:30 PM
orbee's Avatar
anyone ?
Old Oct 15, 2006 | 10:12 PM
orbee's Avatar
everybody and their mom have changed out the front shocks but no replies yet ? or is it because it is Sunday / football ? lol
Old Oct 16, 2006 | 05:00 AM
Foxxtron's Avatar
http://www.ls1howto.com/index.php?article=6
and search is useful
Old Oct 16, 2006 | 07:14 AM
orbee's Avatar
i read that but they did not use their old perch because he had an adjustable one , so what do i dod if i am just replacing my front shocks ? do i reuse the perch or what ?
Old Oct 16, 2006 | 07:22 AM
Foxxtron's Avatar
Okay,
what shocks will you be installing? If you are using shocks that wil require the reuse of the stock lower perch and upper perch, then yes. AFA removing the lower perch, it may require some finesse to remove it, but of course you need to first remove the springs (safely).
Old Oct 16, 2006 | 08:32 AM
Boodyrider's Avatar
And the top perches tend to rust to the shaft of the shock. In many cases they WILL come loose with a BFH, but replacement is indicated if rust requires too much hammering. Also, FWIW, Van Devere Oldsmobile (Google it, go to parts, CALL Dal do not order online) is about the only place that STOCKS the top mounts. Factory top mounts fit the Bilstein shocks, KYBs do not, according to Sam Strano Parts.
HTH
Old Oct 16, 2006 | 10:25 AM
Sam Strano's Avatar
LS1TECH Sponsor
Ahh, I don't recall saying that. KYB's, Monroe, GM are all engineered to fit OEM shocks, and all shocks for the car have to fit where OEM parts do. KYB's will fit as well as anything else. The few times I needed them, I found it cheaper and quicker to get Monroe replacements than KYB or GM.
__________________
Old Oct 16, 2006 | 02:30 PM
orbee's Avatar
i am sure i can replace the shocks myself , but i was wondering about the lower perch . i am going with the blisteins (replacement) and do they come with a lower perch or do i use the exsiting lower perch ? see how confused i am about what appears to be a simple job ? i know i can do this because how many of use here can claim " changing spark plugs on a '" NAVI " lol now that is a fun job ...
Old Oct 16, 2006 | 02:45 PM
chupr0kabra's Avatar
If the shocks you buy don't come with a perch, you will have to re-use your stock one. This is a question you should ask from whomever you buy them.
If/When it comes time to remove the perch off the stock shocks (once you have safely removed the spring), you will need to remove the brass end cap at the bottom of the shock body. It is just pressed on, so a few light taps around the edge of it with a hammer and it will come off. Then you simply slide the perch down off the body of the shock.
-Mike
Old Oct 16, 2006 | 03:04 PM
Boodyrider's Avatar
Sam, that's what Arlyn told me when I ordered the Bilstein HDs...
Old Oct 16, 2006 | 03:20 PM
Sam Strano's Avatar
LS1TECH Sponsor
Hmmm, well that's not quite right. I think she probably mis-understood what you were asking because she knows they fit.
__________________
Old Oct 16, 2006 | 03:47 PM
Foxxtron's Avatar
I believe what was stated about KYB upper spring perches were that their quality was substandard to the OE part, but otherwise I myself haven't had the opportunity to equip them on my street vehicle.
Old Oct 16, 2006 | 07:20 PM
orbee's Avatar
Thanks so much "chupr0kabra" you pretty much answered my question about the lower perch . The problem with the Blisteins is that no matter what website/vendor and/or eBaY they never show a lower perch attached to the shock , why is that ? Thanks again
Old Oct 16, 2006 | 07:26 PM
Some manufacturers sell the perches as part of the shock, some don't. My KYB GasAJusts came with the perches welded on (as do some Monroe shocks, from what I've seen). My Koni SA's (purchased from Sam Strano, btw) came with perches, but i'ts my understanding that Bilstein's don't.
Glad that helped.
-Mike
Old Oct 16, 2006 | 07:38 PM
orbee's Avatar
so pretty much i have to pray that my OG perch's come off smoothly ? Why would they not come with them if they are an OEM part ? weird !
Old Oct 19, 2006 | 07:02 AM
orbee's Avatar
ok let me try this , do the front perch (s) come off the OEM shocks ? and if so can I reuse them on a new pair of shocks ?
Old Oct 19, 2006 | 07:37 AM
Foxxtron's Avatar
yes, the lower perches do come off of the OEM shocks.
no, the Bilsteins do not come with lower perches, nor do the fronts come with dust covers. For the fronts, you must reuse the lower spring perch and the upper dust boots.
Again, you can only reuse them on a new pair of shocks, if the new pair of front shocks don't have them already welded on, or with some that already include their own removable/adjustible perches.
