What torque arm for LT's and true duals?
Was wondering what adjustable torque arm you guys with true duals and LT's are running. And whether its a body mount or tranny mount? Which one is better?
Hello,
With a true dual system that is not custom built you are going to need a long torque arm that bolts into the transmission, the tunnel mounted arms will not clear. We make a very nice adjustable arm that clears fine with a true dual system and in most cases offers addtional clearance and allows you to tuck the system up tigther. Please take a look at the link below and picture, if you have any questions please ask and I am glad to help. Thank you
Ryan
www.umiperformance.com/2205.aspx
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![](http://www.umiperformance.com/images/2205l.jpg)
I have TSP duals dumped and I bought UMI's Tranny mount adjustable TA and it worked great. They have pics on their website with it installed with duals. Great price and customer service...highley recomended!!
Thank you and good to hear!
When that torque arm was designed it was actually designed while using the TSP true dual system. Seeing how popular that system is or similar true dual systems we knew a item that worked well with it and even offered some additional room would be sure to be a hit.
Thanks again,
Ryan
Thanks again,
Ryan
Originally Posted by tensecls1
from the pics i saw that it was a tranny mounted torque arm...will the umi body mounted torque arm fit with kooks long tubes and true duals?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
We always recommend to use our transmission mounted torque arm and torque arm relocation kit.
If I can help anymore please ask. Thanks!
Ryan
how necessary is it to run the relocation bracket for the torque arm?
ive read on here of people breakin their tranny with the trans mounted torque arm...is this only on high power vehicles under extreme track conditions or does this apply to all power levels/driving styles?
id like to upgrade my torque arm the same time im doing the panhard and LCAs and have got mixed reviews as to which to go with...
i will eventually lower the car and run pacesetter/TSP duals dumped so im looking for something thats not gonna give me problems down the line as well
Ahem, not to step on UMI's feet or anything, but there is a tunnel mount option that will fit with duals.
I have the Jegster non-adjustable and it fits great. I broke my stocker and came across this one used for a steal. It may or may not be for you though. The install is lengthy and involved, and you do have to grease the thing regularly (once a month) or it will clunk. Other than that, it lowered my 60' almost 3 tenths. Wheel hop is non-existent.
Jegs and Alston also make an adjustable.
Pics.
![](http://i21.photobucket.com/albums/b293/JPouncey/Jegster4.jpg)
![](http://i21.photobucket.com/albums/b293/JPouncey/Jegster2.jpg)
![](http://i21.photobucket.com/albums/b293/JPouncey/Jegster1.jpg)
This is not to say that I wouldn't get the UMI tunnel mount if they could make it work with my duals. It is a very nice piece, a friend of mine has it on his LT1, and I could actually tell a difference on the street afterwards. The construction is of a very high quality also.
Hint, hint UMI, if you ever need a test car with the duals tucked up as high as possible for a tunnel mount torque arm, I'm your man...
Pics.
Originally Posted by UMI Performance
Doubt It- Yes you are correct, that is another option. The reason I don't mention it is because of the installation time and work involved as well as the additional road noise. I think that set-up is only for certain people.
Thank you!
Ryan
Thank you!
Ryan
If UMI's tunnel mount were available for duals at the time I got the Jegster, I would have gone with it instead, no doubt.
Originally Posted by ryguy85
so im kinda confused on what you are saying here
will UMI's torque arm fit with LT's and the tsp true dual with the transmission crossmember torque arm relocation or not?
http://www.umiperformance.com/images/2320o.jpg
Also sounds great Doubt It, thank you!
