What's the best flat washer?
Old 08-13-2007, 01:56 PM
  #121
Jhankinson's Avatar
If I reverse phase my exhaust washers...will i get more sound and better tone out of my exhaust. Or would it be better to just get washer with more lift and duration so I actually get better power and better sound? last thing I want to do is end up with one of those V-Tech washers and go around looking like a ricer.
Old 08-23-2007, 08:49 AM
  #122
Dmitriy's Avatar
This one time, in band camp... I stuck a washer in...
Old 08-23-2007, 12:20 PM
  #123
squealingtires's Avatar
I'll have to be honest and admit tha I'm way in over my head doing the flat washer mod. My T/A is a 100% street car and a guy that runs low 9's was telling me to install the biggest and baddest washer that I could afford. He told me that it would be very worthwhile to get a washer with lots of duration and to make sure I have it gun-drilled to save on weight. Then he told me about how he went the "custom" route and had his made from ARP 2000 material and had a local machine shop "deck it" .010 to be sure its flat and bore it 30 over in case he ever goes with a bigger bolt. So right now I'm just doing some research.
Old 08-23-2007, 06:39 PM
  #124
monster7's Avatar
dont confuse washers and bushings, what you used was a bushing it just makes things fit tighter
Old 08-24-2007, 08:35 AM
  #125
Well after a lot of research I’ve narrored down my choices for washer selection to one offering. It is a [G5X~3,000,000] from LG Motorsports with a requested full 360 degree duration for both the top and the bottom of the washer. I know it sounds extreme but apparently all of the big dogs are secretly running this washer configuration. I just hope its not too big because I daily drive my car. It's also .300" thick which should be good for nitrous. Do you guys think I can daily drive it or is it too big? Rather than restating the same question 12 times in 12 different threads hoping for some different responses I want to be upfront with you guys so I would like at least 12 different responses before I order it. You can PM me if you want.
Old 08-24-2007, 09:23 AM
  #126
Shock Hawk's Avatar
Do washers come in grades like bolts? I'd stick with at least a grade 8 washer if they did.
Old 08-24-2007, 12:45 PM
  #127
thunderdan74's Avatar
yes they do.
Old 08-24-2007, 12:58 PM
  #128
MrDude_1's Avatar
i wonder if he read the thread.. LOL!!!
(naa, really, i just wanted to use that new : read : smilie.... )
btw, what kind of washers are better, radial or bias ply? i drive 99.9% of the time on the street, commuting, but once every two months i goto the track and expect to dead hook.
Old 08-24-2007, 12:59 PM
  #129
koolaid_kid's Avatar
Originally Posted by thunderdan74
You guys wanna know about washers? Air Force Technical Order 1-1A-8. Everything you would ever want to know about nuts, bolts and other hardware. For those of you with access to .mil websites!
I would never use a mil-spec washer. You have to read dozens of boring specs and requirements, go through acquisition committees, spend 100x times their real worth, procure 50x more than you need, then find out they are the wrong ones. Or the contractor changed where they manufacture them so they have to go through the qualification process all over again.
Old 08-24-2007, 01:01 PM
  #130
On the plus side, I have finally finished my closed loop testing of my upgraded washer set. Next week, I plan on going to the track and start the open loop testing of the upgraded washer set. Wish me luck.
Old 08-24-2007, 01:59 PM
  #131
Well I ordered my washer and it turns out that it wasn't nearly as expensive as I though it would be so I customized mine to be made from ARP L-19 material. At this point I still had some money left over so I went ahead and ordered a 2nd washer. The problem I'm having now is trying to figure out where the best location is to put the 2nd washer is. I've read that a 50/50 weight distribution is not optimal in a muscle car. I put the first washer in the rear-end (can't ever be to carefull with the 10 bolt) since ARP L-19 has an ultimate tensile strength of 265,000psi it should really add some strength to the rear. So, two questions: Will my 10 bolt break and where should I put the 2nd washer?
Old 08-24-2007, 02:08 PM
  #132
MrDude_1's Avatar
well, ive been informed by several reputable non-drag racers that its stupid to have drag car power unless you upgrade your brakes to the size of 14" washers with massive 6 washer calipers.
so to make your brakes stronger, i suggest you put the washer there.
Old 08-24-2007, 06:35 PM
  #133
It is well known that the 10 bolt washer will break under any type of serious power. When it does, A4s normally go to a 12 bolt washer. However, since you have a M6, you should go to the 9 inch washer. Some go to the Dana 60 washer, but fitment can be an issue.
Old 08-25-2007, 10:38 AM
  #134
MrDude_1's Avatar
yea, should i use 4.56 washers or 5.30 washers? currently i have 4.10 washers and i just broke them in my 10washer rear.
im running street tires and currently 60' in the 2.0+washer range.
Old 08-26-2007, 08:24 PM
  #135
poolshark021's Avatar
I can think of a few places...
Old 08-28-2007, 08:32 AM
  #136
MrDude_1's Avatar
GOD im so sick of these noobs and their washer threads!! UGH!!!!
i have no motivation to learn anything else about cars except the washers, so all i ever read is the appearance section.. and im SOOO sick of these stupid noobs posting asking about what washers are the blingyest.... the stock vette washers, the knockoff vette washers, or the washers from another GM model.....
anyway, ive been here almost a year! stupid newbs and their washer threads.. god its annoying.
gee.. i hope noone looks at one of my first posts.. it was asking about what washers are prettiest..... i wonder why noone replied to that thread?
Old 08-28-2007, 09:17 AM
  #137
Jpr5690's Avatar
I Cant Believe This Thread Is Still Alive....
Old 08-28-2007, 09:25 AM
  #138
Kleeborp the Moderator™
MeentSS02's Avatar
Are there any part numbers out yet for the LS3 washers? Will they fit in place of my LS1 washers?
Old 08-28-2007, 09:39 AM
  #139
mitchntx's Avatar
I think it's satire at it's best.
Old 08-28-2007, 10:33 AM
  #140
MrDude_1's Avatar
d0000d!! dAYR duh same washars!! yew stupid!!
and yes.. it IS satire at its best... really, i hope it never ends... its nice to be able to post in here about washers.. no names, no other comments.. just washer satire.
Quick Reply: What's the best flat washer?
