Eibach Front Drag Springs?
Search got me nothing real useful. Figured I'd try to get soem first hand expereince. They make a whole drag kit that comes with front and rear along with a bag.
Anytime I have a question no one ever responds here.
I'm gonna have them here in a week or two so I'll be sure to post about how they work.
you might try this in the drag tech section.
are these a progressive spring? It would help if you knew the spring rates front and rear.
Basically you just need the front spring to hold up the car, and the front shocks to allow the front to gradually come down after you launch. If the car bounces after you launch then something in the front needs to be changed, usually this is accomplished with 90/10s. In the rear you want the springs to be kinda stiff so that the weight transfer at launch gets pushed into the rear tires and not wasted compressing a soft spring.
Good Luck, and keep us posted.
Josh
Josh
