T/A used w/ True Duals?
Kleeborp the Moderator™
I've used an LG torque arm, and soon to go on will be an adjustable, full-length UMI torque arm (full length = transmission mounted). What do you mean by relocation kit? The upper panhard brace relocation kit? A transmission cross member with a torque arm relocation on it?
UMI makes a relocation kit that takes the front of a stock, full-length torque arm off the transmission and onto the body. It looks pretty nice, but a little expensive. Is that what you are talking about? They told me it should work with true duals (a long time ago), but I don't have it.
Hello,
Our adjustable transmission mounted torque arm is designed to clear with most true dual systems as well as add addtional clearance over the stock torque arm. We can't guarantee this on custom set-ups but we have never had a issue and always have great results. The picture below shows this torque arm installed with the TSP True Dual set-up, it allows us to tuck the exhaust system up 1" closer then the stock arm would. If you click on the link below more information and pictures can be seen. If you have any questions please ask. Thanks! Ryan
www.umiperformance.com/2205.aspx
I think if you read the ad in the link it will answer all your questions. The relocation kit has nothing to do with true duals.
www.umiperformance.com/2207.aspx
Hope that helps,
Ryan
Hope that helps,
Ryan
Originally Posted by UMI Performance
Hello,
Originally Posted by ls1mightymouse
Ive had TD's on 3 of my cars and had the Random Tech T/A on all 3 as well and havent had to relocate anything
Hope that helps,
Ryan
Originally Posted by PowerShift408
Spohn's torque arm come sith the relocation bracket for 360 bucks, but maybe I'm missing something here. I sent them a message, so we'll see.
Ryan
So I need to spend 240 bucks on a relo. bracket on top of my torque arm.... ****.
Thanks,
Ryan
Well give me your opinion... 9"/spool, M6, 500+whp for now (possible in the 650 range in the future w/ nitrous if I choose to do so). What do I need to go with?
That's what I thought Matt. I think I'll go ahead and grab the relocation kit w/ their Christmas deal going on right now, I can't quite swing both at the same time though.
I think I've been swayed to UMI after seeing how much they are on here helping out customers. I don't see BMR or Spohn on here doing the same thing.
