What Is The Difference In The Supsension Of A Stock T/a Vs Ws6
Old 01-25-2007, 10:07 AM
chadnol10's Avatar
Default What Is The Difference In The Supsension Of A Stock T/a Vs Ws6
Just as title reads from new what is the difference between a stock Trans Am vs. WS6
Old 01-25-2007, 10:27 AM
LS1W66's Avatar
`96-`00
Stiffer springs
Different Shock valving
32mm front sway bar
17" rims and tires
`01-`02
Shock valving
32mm front swaybar
17" rims and tires
Springs are the same as regular T/A and Formula
Old 01-25-2007, 10:30 AM
chadnol10's Avatar
so are you saying that my stock trans am should have a front sway bar then because it doesn't now wasn't sure if someone took it off. If so are you saying that it just wouldn't be as stiff?
Old 01-25-2007, 12:00 PM
LS1W66's Avatar
All the cars have a front swaybar the standard bar is 30mm the WS6-SS front bars are 32mm.
Old 01-25-2007, 01:13 PM
torlak_t's Avatar
doesnt hv a sway bar!!
Old 01-25-2007, 01:54 PM
BLK02TA's Avatar
Ya???
Are you sure you're looking in the right spot????
Old 01-25-2007, 02:06 PM
jb442's Avatar
Ok, this is off-topic, but I just noticed something in your sig torlak... Is that a picture of your dash, or someone else? If it's yours, I hope your oil pressure gauge is off because it looks like you have about 30 PSI @ 6000 RPM!
Old 01-25-2007, 02:09 PM
SmokeySS's Avatar
Maybe he bought a used drag car and the previous owner took it off?
Old 01-25-2007, 05:53 PM
torlak_t's Avatar
maybe its a photoshop i cant take clear pics while driving my car
Old 01-25-2007, 05:57 PM
01FbTaWs6's Avatar
LMFAO!!!!!!!!!!!
Old 01-25-2007, 06:12 PM
torlak_t's Avatar
i can send you a video that i hit 140. shall i?
Old 01-25-2007, 11:44 PM
98_1LE's Avatar
Originally Posted by LS1W66
`96-`00
Stiffer springs
32mm front sway bar
17" rims and tires
`01-`02
Shock valving
32mm front swaybar
17" rims and tires
True, except most 2000 WS6 got the base T/A springs. I have read the cutoff was around 11/99 build date.
Old 01-26-2007, 12:24 AM
jb442's Avatar
I'd photoshop it up to... oh, about 60 PSI or so before it 'splodes!!! Ok, ok... I'll stop now.
Quick Reply: What Is The Difference In The Supsension Of A Stock T/a Vs Ws6
