Did the heater hose mod - car is still at stock ride height, wtf?
I measured before I did the mod, 28" from the floor to the center of the wheelwell. Did the mod - still 28"! I installed a pair of Bilsteins at the same time, but I don't think that would have any effect on ride height. Should it settle a bit after awhile?
Okay... I feel your pain. Try this- check to see that the springs are "indexed" on the perch. They turn a little, and that can make a difference, so spin it around some and try it. Also give it a little time, because they can/will settle. I got a 1/2" drop after a week.
try driving it around. Do some acceleration runs to try and get the back end to squat. I found this out when I put height adjustable QA1's on the front. I adjusted to the ground clearance I wanted, after driving to the alginment shop, they couldn't put it on the rack. The front had settled ~7/8". definately drive it before measuring
Pontiacerator
Yeah, the hose is not overlapped - Which way should the tail of the spring face on the perch? I have them both pointing toward the pass side of the car at the moment.
Originally Posted by michaelg589
ok, dumb question... whats the "heater hose mod"
Replaces the thick rubber upper spring perch with a thin piece of heater hose to lower the rear of the car ~ 3/4 of an inch.
