What is squeaking like an ...
Old Feb 9, 2007 | 02:37 PM
SSTowerman's Avatar
Default What is squeaking like an ...
old spring bed getting humped in? Driving me crazy every time I go over a speed bump. Shocks, springs, or bushings. Maybe all, I dunno. I have KYB AGX adj shocks, stock springs and bushings.
Old Feb 9, 2007 | 03:21 PM
02TransAm/Batmobile's Avatar
i hear some squeaking too, in the back rear wheel wells, . i think its my lower control arms cuz i raced a gto from a roll, . popped it into second and took off like a bat outta hell, . . ever since then, i hear sqeakin from the back, ..
Old Feb 9, 2007 | 07:09 PM
monsterbreather's Avatar
cold weaher,, probly the swaybar insulators if in the front, i jus greazzd mine
Old Feb 9, 2007 | 07:15 PM
Arctic2002ss's Avatar
It's most likely the Lower Control Arm bushings.
Old Feb 9, 2007 | 07:56 PM
SSTowerman's Avatar
Ya I'm leaning toward the LCA bushings.
Old Feb 9, 2007 | 10:35 PM
mycamaroSS's Avatar
dude i think we all hear it, i just turn up my radio and it goes away until i turn back down. most annoying sound
Old Feb 9, 2007 | 11:41 PM
mycamaross, . your everywhere on this forum aren't you???!
Old Feb 10, 2007 | 12:54 AM
916LS1's Avatar
I had this stupid squeaking in the back, near the tires. It turned out it was my E-brake cable rubbing against my panhard bar. I bent the brake line away from the PHB, and haven't heard the noise since.
Old Feb 13, 2007 | 07:42 PM
import slayer's Avatar
I just started hearing the squeaking too. It is anoying as hell!!!!
Old Feb 14, 2007 | 01:14 AM
SSTowerman's Avatar
FWIW, I squirted some WD40 on the LAC's and she's a helluva lot quieter. Still got some kinda spring squeak in the upper wheel wells of the rear.
Old Feb 14, 2007 | 09:09 AM
LeftySS's Avatar
check your bushings on top of your shocks in the back, every so often i have to put some white lithium grease on them and it makes the squeaking stop. for awhile!
Old Feb 14, 2007 | 01:59 PM
SSTowerman's Avatar
Thanks.
Old Feb 15, 2007 | 06:50 PM
my car does not start to squeak until I go over a few bumps. And once it starts to squeak it will squeak at idle sometimes. I put my car on a lift and messed with it a little with a friend of mine and we could not find anything. This noise is starting to get really annoying.
