ABS on rough road
when I would drive in gravel parking lots the truck would turn on the abs very easily and not let you stop even though you would have been able to stop if it had not came on.
on my current cars I don't have this problem though.
a few other cars I drove were like that, just too sensitive.
Warped rotors = bumps in roads : Like when the tires leave the ground for those split seconds and are easily locked by the calipers, the warped portion of the rotor will press more firmly against the brake pads and make it easier for the caliper to lock that wheel and cause the ABS to kick in.
I think you're describing the traction control system, ABS was not designed to work on rough road surfaces and I've heard it does increase the stopping distance.
Anyways, the fact is that ABS was created to decrease stopping distance by keeping the wheels moving instead of skidding.
