Do u get a 35MM/21MM sway bar with the Bilstein Level II?
i think slp started this on 2000... pre 00 bilstein was 32/19 and 300-450 lb/in 115-185 lb/in and 1le was done in house by GM... same as below except with the 32/19 combo
BILSTEIN ULTRA PERFORMANCE SUSPENSION SYSTEM
35mm front stabilizer bar
21mm rear stabilizer bar
Reinforced stabilizer bar brackets and special end-links
Bilstein shocks, recalibrated to SLP specs.
Progressive-rate front springs 223 to 448 lb.-per-inch
Progressive-rate rear springs 97 to 136 lb.-per-inch
Rear trailing arms with 1LE bushings
1LE panhard bar
Option Price: $999
1LE SUSPENSION SYSTEM
Double-adjustable Koni shocks
Linear-rate front springs: 360 lb.-per-inch
Progressive-rate rear springs 130-170 lb.-per-inch
Front lower control arms with higher durometer bushings
Rear trailing arms with higher durometer bushings
Panhard bar with higher durometer bushings
Option Price: $1,850.
1LE panhard bar
Option Price: $999
LS1TECH Sponsor
Some did... only Ultra Suspension and the 01-02 SLP built 1LE's had the 35/21. Their front is hollow too, the rear is solid. And SLP no longer makes that bar (and when they did I didn't use it because they wanted $299 just for the front one).
If you have those bars, I do not have folks change them. Well, not the front one anyway since there is no gain. The rear bar we might change since mine is about 5-6 pounds lighter, and it's also 5-6 pounds of unsprung weight removed too.
__________________
