Panhard Bar.....worth it?
alright guys i'll be honest, i dont know a damn thing about chassis/susp. parts. what exactly does a panhard bar do? is it worth it?
i did a search btw...
I just installed my UMI on car adj. bar and i definitely say its worth it! My stocker was slightly tweaked and the *** end feels so much tighter now. To be honest i wasn't sure if it was going to be worth it but i had to get one becasue i'm lowering it but now I wish i bought this a long time ago.
It's worth it in my opinion. The side stepping in corners is really annoying and the PHB got rid of it. Also, a rod ended PHB will not increase noise or vibration and allows for easy adjustment.
Moderator
You do already have a Panhard rod of course, it's
just stamped and not as stiff as most aftermarket
ones. I would not spend a dollar on a nonadjustable
replacement. I got a used Hotchkiss one for pretty
cheap and it's fine (even though I "adjusted" it to
match stocker length on the driveway, put it in and
haven't turned the nut since). To tell you the truth
I noticed nothing from it and I tend to take corners
"enthusiastically". But it seemed like something to
do, since I was fixing to change everything else
around it eventually.
my car, the passenger side tire sits in under the wheel well farther then the one on right driver side, would an adjustable pan hard bar fix this? do you think my stock one is bent causing this? could it be anything else?
How does one adjust the PHB? How do you know when its centered? Came home to visit my folks for the week-end and found that my PHB, LCAs and Relocation brackets had come it, finally! I'm wondering how the hell am I suppose to center it.
