crank pully rubbing on sway bar
Do you have any pics? Is it a stock bar, stock pulley? Have you gotten under the car to take a look at the swaybar to make sure both the endlinks and bushings are still connected.
When I got my car the sway bar was rubbing on the pully. Of couse it was because it was wercked and the mount on the passenger side was pushed up 1.5 inches. The mounts on the frame rail for the sway bar would have to be bent or the bar itself bent in the middle. Check there first.
LS1TECH Sponsor
Originally Posted by BMR Fabrication Inc.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
Nope..... The links could be gone and it wouldn't hit the pulley if it's on right-side up.
__________________
