C5 & C6 Brake Conversion Part Number List
Old 07-22-2007, 08:55 PM
02TransAm/Batmobile's Avatar
Default C5 & C6 Brake Conversion Part Number List
C5 Twin-Piston Caliper with 12.8" x 1.25" Rotors
12530681 - OEM Front Brake Pads (No hardware)
18039366 - DuraStop Front Brake Pads (No Hardware)
88909667 - Ceramic Front Pads And Hardware
12480154 - Hawk HP + Front Brake Pads (No Hardware)
88952008 - C5 Z06 Front Pads and Hardware
12530683 - Front Left Caliper (Black)
12530682 - Front Right Caliper (Black)
88895128 - Front Left Caliper (Red C5 Z06)
88895129 - Front Right Caliper (Red C5 Z06)
10445856 - 12.8" C5 Rotor (Passenger)
10445857 - 12.8" C5 Rotor (Driver)
88926732 - 12.8" C5 Rotor (Cross-Drilled) (Passenger)
88926731 - 12.8" C5 Rotor (Cross-Drilled) (Driver)
12455799 - Caliper Abutment (Right-Hand and Left-Hand)
12530703 - Caliper Abutment Boot (2 Required per Caliper)
12530697 - Caliper Abutment Pin (2 Required Per Caliper)
14067559 - Caliper Bolts (2 Required - Included w/Caliper)
22163795 - Caliper Banjo Bolt (2 Required) ***
10139097 - Caliper Banjo Bolt Washers (4 Required)
C5/C6 Twin Piston Caliper with 13.4" x 1.25" Rotors (RPO Z51 Package)
89060211 - OEM Front Brake Pads
88909667 - Ceramic Front Pads and Hardware
88964164 - Front Left Caliper (Black)
88964165 - Front Right Caliper (Black)
89060328 - 13.4" C6 Rotor
88964166 - Caliper Abutment (Right-Hand and Left-Hand)
12530703 - Caliper Abutment Boot (2 Required)
12530697 - Caliper Abutment Pin (2 Required)
14067559 - Caliper Bolts (2 Required - Included with Caliper)
10139097 - Caliper Banjo bolt Washers (4 Required)
C6 Six-Piston Caliper with 14" x 1.25" Rotors (RPO C6 Z06 Package)
19121809 - OEM Front Brake Pads
19121788 - Front Left Caliper
19121789 - Front Right Caliper
19121787 - 14" C6 Rotor
22163795 - Caliper Banjo Bolt (2 Required)***
10139097 - Caliper Banjo Washers (4 Required)
*** - Not needed on 4th Gen F-Body Vehicles. Reuse Stock Banjo Bolt
Old 07-22-2007, 11:13 PM
LilJayV10's Avatar
So did you decide to do the vette upgrade?
Will the Z51 and and the later Z06 calipers work with trackbirds brackets? I have the part number for the two piston calipers. I didn't know about the other ones.
Also, does anyone know what the rear caliper part numbers are, I was about to post a new thread when I saw this one.
Jason
Old 07-23-2007, 12:26 AM
Nah, I didn't go for the 'vette upgrade. I was so close to doing it, I had the relocation brackets and everything. (Which is why I have this part number list) But at the end, I didn't think it was worth the money/hassle in my setup. I will be looking towards Force 10's SSBC 4-Piston direct replacement calipers
I am pretty sure that the brackets will fit with the C6 Z06 calipers, but don't quote me on that. The rear C5 calipers are 99% identical to the LS1 F-Body Calipers. I think the only difference is the offset of the Caliper to coincide with the offset of the rotor.
Old 07-23-2007, 08:31 PM
wannafbody's Avatar
can you post a link to the Force 10 calipers? What do they cost?
Old 07-23-2007, 09:02 PM
It's a non-sponsor. Just google SSBC. The kit is about 1100 bux and comes with all necessary hardware. It even comes with pads, rotors and stainless steel lines. I'm going to ask for a price on just the Calipers to lessen the cost.
Old 07-23-2007, 10:02 PM
wannafbody's Avatar
after seeing the SSBC calipers in person I'm of the opinion that they alone with 12 inch stock rotors would be sufficient for most people including those who open track their cars. The bolts that are used on the calipers look to make a stronger caliper than a cast caliper which I have read can melt under racing heat.
Old 07-24-2007, 11:09 PM
Cool, I wonder how much the calipers alone cost?
Old 07-25-2007, 09:54 PM
wannafbody's Avatar
they make a couple different types- they have a 2 piece held by bolts and nuts and a one piece that is cast. The one peice seems to be the direct replacement caliper and IIRC it has 3 pistons.
Old 07-26-2007, 12:02 AM
spy2520's Avatar
i believe several of our sponsors sell SSBC brake kits so it should be alright to post.
Quick Reply: C5 & C6 Brake Conversion Part Number List
