tq arms for true duals
i have no time to search this but if i can get a quick answer or so that be great..
i have the tsp duals and i need a tq arm with a loop to fit that. what can i do? i have a bmr stock replacement.
but now i dont wanna rip the tail shaft off and my track over here requires safety loop. thanks guys
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Hello,
None of the shorter tunnel mounted torque arms with built in loops are going to clear with the TSP true duals. If you want to get the torque arm off the trasmission you need to go with a torque arm recloation kit. Check out the link below, we have them for the automatics as well, just not on the site yet.
http://www.umiperformance.com/produc...category_id=46
If you have any questions please ask. Thank you!
Ryan
Ryan
Originally Posted by OldeSkool
you could do a jegs torque arm and a stand alone tunnel brace loop
For a loop, I think the Lakewood driveshaft loop will clear the TSP system just fine. TSP might now, I would ask them.
Hope that helps,
Ryan
Originally Posted by UMI Performance
Yes this is a option. But the problem with the Jegs torque arm is it requires you to pull the interior and drill about 20 holes in the tunnel to install it. It is also noisy. But it is a option..
