Strano springs pic
Originally Posted by SsycoticSS
looks awesome!
Hows it on bumps?
I have Koni's SA's with DMS springs. But they hit HARD!
Hows it on bumps?
For the record it has the isolaterin the rear, and is on the lower perch in the front. I decide to try it, because I have 245/40/17's on the front and they are 24.5 ish tall, and it has about a one inch or 2 tight fingers gap in the front. The rear are 295/35/18
Measurements are
LF 25 3/4
RF 25 1/2
LR 27 1/2
RR 27 1/4
Measurements are
LF 25 3/4
RF 25 1/2
LR 27 1/2
RR 27 1/4
Measurements are
LF 25 3/4
RF 25 1/2
LR 27 1/2
RR 27 1/4
Measurements are
LF 25 3/4
RF 25 1/2
LR 27 1/2
RR 27 1/4
For those out there freaking out about the ride height, *remember* the tire sizes being used. Fronts are short, which will lower the car. Rears are not, most likely taller than stock and that raises the car. Hence the lower front, higher rear ride height than what others see.
__________________
Good point on the stance Sam, I wanted the big and little street rod look, thats why the fronts are smaller. With the bottom perch on 275's in the front I doubt there would be much gap at all.
I have adjusted the fronts a bit I have them a 5 sweeps from full hard, and its a nice.
DAMN, that looks very good. Thats the lowest F body Ive seen with strano springs but like Sam mention you will see lower in the front with the taller wheels and the rear also taking up more gap in the rear as well. I like it. Clean LT1!
mucho sexy!
thats the exact kinda stance i am looking for in my car! what kinda exhaust are you running? do they scrap alot? or is it just the ussualy take the speed bumps and drive ways at an angle?
Originally Posted by stangkiller2005
mucho sexy!
Thanks for the nice words guys.
It's lower because of the tires. Seriously. I weighed my LS1 car vs. an LT1 car with the same options (except they had T's and I have a solid roof) back when I was autoxing in stock category. 6 pounds different, and my car was heavier. Both cars had the same wheels, tires, swaybar, upgraded stereo, power seats, etc.
__________________
