Nose dipper
I already have aftermarket sway bars, shocks, LCA, PHB. I have stock factory torque arms, no sub-frames, however.
...nose droop not all that bad but not much different with new stuff.
If you make the car not dive at all, it won't stop. And springs won't stop the dive, and will make the ride more firm.
make big forward weight transfer on braking. Springs resist the
deflection from it, shocks resist transient deflection, if it's more
of an overshoot than a steady squat then more bump damping
might be desirable. Not much you can do about brake bias if
you want to keep ABS.
How; what are the alternitives?
