quick relocation bracket ?
when you get on the throttle, the rear axle wants to move forward, and without the LCA's in place, it would do exactly that....only without the car moving forward with it (that would be bad). with the LCA's in place, the rear axle pushes against the LCA's, and the LCA's push against the car's body, causing it to move forward.
however, you can lose/gain traction multiple times per second because when the LCA's are level, they don't have any resistance to upward/downward motion, just forward/rear motion. when the LCA's start moving upward, it allows the tires to grip a little, because the rear end is allowed to move forward a little more than the body, since the LCA's are not able to push against the body. it can only go so far, though, and when it rebounds back into place, the wheel slips again. repeat this several times per second, and your wheels start hopping on/off the pavement.
when you change the angle of the LCA's from level to a downward angle (lower side at the axle), that keeps the LCA's from being able to pivot upwards whenever the tires start to grab, which reduces the wheel hop (this is good). the bad part is that if you are still on non-sticky street tires, instead of getting wheel hop, something else has to give, so the tires just keep spinning.
get some good sticky tires.
