Old 05-10-2016, 03:18 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevoret Camaro or Pontiac Firebird Brake Guides
Print Wikipost
Abs Inop, Brake Light, Trac Off
Old 01-17-2008, 07:18 PM
  #101
Benner's Avatar
Okay I read my ABS codes at work today with a Tech II and it came up that I am having a rear wheel speed sensor malfunction. I'm gonna replace it in the next couple weeks so hopefully that'll help
Old 01-19-2008, 10:48 PM
  #102
cabesas's Avatar
Originally Posted by Sideways240sx
I have no idea why this happens, or if it will help you guys at all. But when ever i run my slicks on my car. 11.5x26x17 mt et street, i get all 3 lights when driving. Abs inop, traction, and brake. WHen i put on my bfg 275-40-17's they all go away. Im guessing somehow it has to do with the vibrations and shaking in the car since the et streets dont have a steel sidewall. I know 100% for sure putting slicks on makes all 3 lights come on on my car. I have tested over and over again, and switching tires fixes for me.
Good luck, Chris
Ps.... Anyway maybe rims being out of balance, or car needing alignment could reproduce a similiar shaking, and make these lights come on. shot in the dark. Good luck.
I got this problem too every time i put the et streets lights turn on when i keep a steady speed of 35 when i put my other wheels on its normal. Is there a way to fix this?
Old 01-21-2008, 08:28 AM
  #103
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
It does it when you change wheels because your fronts/rears are not all the same size. It can't sense slip when they are already spinning different speeds, so it turns the ABS off.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 01-21-2008, 06:49 PM
  #104
mike1500's Avatar
Just to update everyone I havent been able to do anything else yet to investigate this issue
Old 01-22-2008, 01:26 AM
  #105
minesfaster's Avatar
Mike i think you needs' to higher a private investigator ! lol j/k
How about a fuse ?
Old 01-22-2008, 09:40 AM
  #106
mike1500's Avatar
How about a fuse ?
Checked and even tried to clean almost every fuse contact.
I think your onto something with the investigator idea lol
Old 01-22-2008, 03:40 PM
  #107
Or just bring it to me and i will fix it for $50.......
Old 01-28-2008, 12:34 PM
  #108
mariojmoe's Avatar
I thought I was the only one with this damn issue. 98 SS that was a theft then threw in a fresh water lake. I stripped the car (from what was not already missing) and swapped everything from a 2000 rolled SS including abs sensor and all sensors (wheel). abs light stays on and brakes are horrid and spongy. I took it to brake specialist and had all new pds and rotors installed and cleaned and re-installed the abs block. No luck. Re-bled the brakes and abs pump, no luck. Brakes are still horrid only difference is my brake light does not come on only abs inop. Any suggestions?
Old 01-28-2008, 08:14 PM
  #109
mariojmoe's Avatar
Ok, just got back home from Mienikie (sp) They ran the coder and found my front right sensor was bad. I had them replace both front sensors with brand new ones. The difference now is I can feel the abs working in the front and it does stop a bit better but the rear is locking up and of course the abs inop is still on. Tomorrow two brand new wheel speed sensors and another 300 bucks. I'm praying this will cure the issue, if not I might look into selling this thing
After replacing the sensors I found out I need both left and right front rack and pinion and control arms plus a p/s pump.
Old 01-30-2008, 07:23 PM
  #110
redramair98's Avatar
any of you other guys solve your problems
Old 01-30-2008, 07:24 PM
  #111
if anyone needs a traction control abs module i have a good one from a 01 ss camaro with right under 35,000 miles on it
Old 01-30-2008, 07:56 PM
  #112
robster's Avatar
how much?
Old 01-30-2008, 08:42 PM
  #113
Mike is giving up and selling his car !
Old 01-30-2008, 10:31 PM
  #114
shannon french's Avatar
maybe try your wheel sensors. i had one on a grand prix come a lil loose and needed dielectric grease and its now fine. thats what disabled my abs and traction control on that car.
Old 01-30-2008, 11:10 PM
  #115
pm sent robster
Old 01-31-2008, 07:31 PM
  #116
mariojmoe's Avatar
Damn abs inop still on, re-cleared the code three times and it pops right back on saying right front sensor? I just don't know what to do??????
Old 02-01-2008, 05:54 PM
  #117
trez2k3's Avatar
Finally got a module in from the same year car and one w/ tcs. All lights off now except for TCS OFF and I can't toggle it on or off. That doesn't even bother me as I turn it off everytime I get in the car anyways. I did bleed the brakes though and still have a squishy pedal, any idea what thats about? PS also I don't think the dealer reflash thing matters, but it may be that the module's are year specific. I tried 2 from different years and the lights didn't go out. Thats not to say a reflash wouldn't fix that.
Old 02-01-2008, 06:10 PM
  #118
who281's Avatar
MINES FIXED!! finally..
well mine ended up being the speed sensor...
i thought it had been replaced but i guess not.. so i got the hub/speed sensor ..
and now so far so good no lights BS works great and TCS works to..
Old 03-23-2008, 08:47 PM
  #119
who281's Avatar
o by the way it broke again about 4 days later... and no one has any idea whats goin on ive had two diff mechanics ive gone through 3 hubs/speed sensor setups.. bleed the brakes changed the pads checked the TCS module...nothing works!!!
Old 04-17-2008, 11:44 PM
  #120
mike1500's Avatar
that sucks hard dude, still having the issue here
Quick Reply: Abs Inop, Brake Light, Trac Off
