rear brake rotors
rear brake rotors
i feel like an idiot for posting this. couldnt find anything on it?
i looked in my haynes manual, i'm doin everything right from what it says, but haynes manuals arent the greatest.
tryin to remove my rear rotors from my 02 trans am. the brake calipers/brackets are off. nothing but a rotor sitting over the studs (yes, i removed the lockwashers). the rotors will NOT budge eve a little, there is absolutely no play, and even with a hammer they wont budge at ALL.
am I missing something??
Thanks in advance
Thanks in advance
okay... i just wanted to make sure i didnt miss something.
i've tried penetrating fluid, guess i'll try more! time to start poundin on it with my sledge again!
next step is a torch to see if i can heat up the brake a lil to loosen it up
I used the blunt size of a wood splitting axe
And I had the e brake engaged as well. The worst part was that I couldn't figure out that the circular piece thing was the ebrake shoe for like an hour at least.
well... i got it finally. sprayed more penetrating fluid... let it sit. started SLAMMIn on it (i'm 6ft 240 lbs) and it finally after about 5 minutes of slammin popped loose.
passenger side was a little easier, but i actually BROKE the rotor i was hitting it so hard. lmfao.
Thanks for the help guys!
